The top end is off the engine, and things have been evaluated ... I haven't finished taking photos yet.
The lifter lobe face shows it's been spinning. In fact the lifter body shows that too. There's the typical band at the bottom, then I've got one above that showing evidence it's been spinning a long time. There are some vertical scratches too.
There are some odd tiny black specks on the face of most all of the lifters, all sort of in a line. I don't know what to make of that. The cam shows age and use too. It's one of the early radical 509 hydraulic cams before they changed the lobe center to calm it down some. The jury is out on reusing it - if it stays a 440 I may move up to something like the old 590 solid purple shaft.
The cam bearings are in one piece and show signs of scraping so they've been replaced at least once but look to be usable.
Pistons are L2355, +.030, forged. They're about .018 in the hole measured with a feeler gauge. The bores are smooth, no cross-hatch left. There is no ridge or noticeable damage. I noticed one tiny speck of rust or something that wouldn't just wipe off in one cylinder. There may be more. It's going to need honed anyway it goes. The block's destiny probably depends on how out of round things are. If possible I will hone it and go.
The heads are 72-3 346s, basically 452s (ports are the same). They may be the originals for this block. Someone has put some work into them. It's hard to say how much, but after looking at another set it's obvious the grinder's been around the valve stem and the casting crap has been smoothed out. The engine side has been sprayed with chem-dye, but there is still > .020 lip at the edge of the chamber so I don't think they have been cut. Maybe somebody did that to check level on the deck surface the hard way? Don't know.
There don't seem to be any sunk valves unless they're all sunk. The valve tops are pretty much level, side to side. These have double valve springs with dampers. Why? Maybe race car? I don't have a valve spring tool that's up to the task so I don't know what the stems or seats look like. If that all checks out OK I think I can get by with no machine work here. If these go back on I will probably run a steel shim gasket.
I have another set of heads that could be useful. Those are 915 HPs, big valves, closed chambers. These are stock castings, never touched by a grinder. At least one of the exhaust side bolt holes is stripped and won't hold a stud or bolt. That might end up needing a machine shop to put threads in the open hole. I don't think a heli-coil is the solution. I stuck a straight edge across the valves on one of them and they're kind of all over the place. I see them needing a machine shop to make a good set, and I'm not sure they're worth it to me. OTOH I just checked and you end up with nearly $2k in a set of 440 source heads once you're done.
I've also got four other 452 heads, two that were involved in the infamous intake full of coolant event. If Jass was here he'd post a photo. Anyway, I think at least one of those is cracked because how the hell else do you end up with coolant in a big block intake? IIRC the other two look like a monkey tried to port them with a chisel and a file.
Next stop, bottom end, where we find out how many cubic inches this engine is going to end up with. That all depends on the crank. If it just needs polished, I'm gold. It's forged; the engine is a non-HP 72 model motor. I have confidence in it; there was plenty of oil pressure when last started. But if it's chewed up it might be time for a stroker crank.
Another factor is the bore. I hope I can just hone the crap out of it and move on with my life. But if it has to go to .060, that means new pistons, then rod resizing because the rod/pistons need the machinist to press the pin so why not, possibly balancing, so maybe I should start adding it up and thinking more about that stroker kit.
But I really hope to end up a 440 in the end simply because that's expensive enough.
FWIW I'm starting to work, slowly, on the door mechanisms and glass too.
