71ChargerRT
That's a pretty cool setup. Still not going to work for me, I don't want to have to redo the A/C in the next couple years.
Sorry, my intention wasn't to indicate he should just get mains. The online suppliers I mentioned were for complete springs--they don't sell components thereof.Its going to need more than just the mains to get the springs right. Every leaf supports the one above it. It is a system.
I'd also suggest completely cleaning the exterior of it, starting with a power wash and ending with Scotch-Brite and bare metal, then priming and painting it.
Use the best epoxy primer you can find. The paint isn't critical, anything will do. It's the epoxy primer that will do the protecting, the paint just keeps the epoxy from UV exposure.
Damn, dude... send me half of the savings as a "thank you" gesture! The $300 option. They're not the only guys doing springs around this price range, but that was the first thing to come up in my Google search. I found them when I was looking for springs for mine own wagon. The local spring shop told me to buy from one of the online places; they couldn't touch the price.I did get a quote on springs, almost $800 to my door, I believe it was Eaton.
On the shocks, I'd recommend KYB Gas-a-Just if they're available. It's the same design as Bilstein's monotube gas (they share the patent), but much less expensive. Yes, the Bilstein is without question a better-quality shock, but they're about twice as much money. You've got pretty big grocery bills to consider. You'll get 50-60,000 happy miles before the KYBs need attention. That's a long time in a hobby car.
Rancho 9000s aren't Bilstein or Koni. They're made by Monroe, so like everything Monroe (Tenneco) sells, they're overpriced, overrated garbage.
Pretty sure you're going to find out they're not the same springs. They may bolt in well enough, but expect Sag City back there. The wagon springs are considerably more robust, owing to the extra 500+lb over the rear wheels.I found General Spring earlier today looking for leaf spring dimensions. I also realized I have the zero cost option, the rusty carcass of the 300 uses the same leaf springs.
