I said I was going to do it...
...and I did. In the thread about my efforts to regain driving priveleges, I mentioned buying the neighbor's Dakota. Well, I bought the neighbor's Dakota and I'm already referring to it as "The Goat".
It's not a bad little truck for $500. It's a '92 LE, 3.9L Magnum/5-speed, 4WD extended cab. It has typical rust issues, but far less than one would expect to see in this area after 22 years. It's a little soft in the extended-cab area, the driver's floorpan has got a hole, and the lower edge of the outer tailgate's ragged. The rear bumper was smote by the rust gods--helped along by the former owner's attempt to move what was apparently a redwood by getting a running start with a chain. :doh: I ordered a new step bumper for it ($160 W/brackets) and I'm just going to patch the other areas I feel need attention.
Mechanically, it's pretty much a gem where the big stuff is concerned. It runs quite well; I was surprised at how snappy the little six is. The clutch is in good shape, and the original R12 freon is still in the ice-cold AC after 144,000 miles. The 4WD works perfectly. The previous owner put less than 200 miles on it in almost a decade of ownership. I put an unnecessary new Mopar starter in it a couple of years back (it was/is the positive battery cable, which needs a proper repair end) and the truck had not moved from that spot since. The fuel pump is questionable, but I'm not 100% sure that's the problem just yet... I'll know more when I lift the box off it. Realistically, once that's sorted it could be driven the way it is, but since I have the luxury of some time before it's needed and a hoist at the shop, I'm going to take care of some things I'd rather not wait to become a real issue.
Like every other LA-based Magnum engine, it needs a plenum gasket. While I'm at that I'm going to do the cap/rotor/plugs/wires and swap the belt and idler/tensioner pulleys, which only make noise when the air is running. The radiator's a little soft at the bottom but holding; a new one's on the way, as are the hoses which are the truck's original 1992 equipment. The exhaust system has a new muffler but the pipes are getting a bit ugly, so I'm going to do a pre-emptive strike there and change those at work, and while it's in the air I'll repair the rotten front-to-rear brake line. Just a lot of little, inexpensive stuff. I'm putting new parking-brake cables in it, since I hate the "leave it in gear and call it good" mindset. Just a lot of little, inexpensive stuff really, so I'm not terribly bothered by the work it needs. Like I said, I have time to accomplish this stuff and none of it's expensive ($123 for a fuel pump, $89 for a radiator). I'll have less than $1,000 into the whole shebang when I'm done, including the price of the truck. That's a steal for a fairly-solid 4WD truck in these parts... normally that kind of cash will get you a beat-down '82 Ford with a 300 six and rust to the door handles if the 4WD works.
If any of you current/former Dakota owners are aware of problems spots I should check, please chime in here and let me know. I have a 20+ mile commute, so reliability is of the utmost and I'd like to address anything sooner rather than later.
Oh, yeah... check out the awesome solution he devised for a radio that just didn't fit in the hole. :D :D :D
He was totally unaware of even the possibility of a $5 adapter plate available damned-near anywhere:
I like it Doc...Congrats! It should be a sweet little commuter for you. And all the little stuff is just as you say...not expensive, but time consuming. And it's great you have a shop you can work on it at, and the time to get all those little things sorted out.
Yeah, and for this area that's truly minor rust damage. Hell, you must've noticed that when you were here to retrieve the Fish. :doh:
yeah especialy after BASHING fishys 300-6 ford 4x till the cab fell several inches..the seatbelt fell out of the truck..and the front drive line grenaded...yes cancer is NASTY out your way...its actualy terrifying....what we consider a rusted heap out here....you guys consider rust free
Those were some entertaining pics. Was there a video too? Can't recall?
yes..and ALOT of it...and pics that never surfaced...the whole drive crashed and all was lost...ive actualy recovered it and been meaning to get it to fishy to sift thru
I'd like to see those again...I remember giggling like a fool.....:D
I'm hoping to have a solid day of work on the truck this weekend... the bossman indicated he may be staying late after work tomorrow night, and also may be going up to the shop on either Saturday or Sunday. That would allow me to get the truck into position for the hoist and lift the box so I can check out the fuel pump. If I get time, I'd like to finish that then get started under the hood. I've got a big box of joy sitting here full of underhood items that I want to tackle while I'm doing the intake manifold: all the tune-up parts, a thermostat, hoses, belt, idler & tensioner pulleys, hoses, etc. I got the new radiator as well, so while I'm in there I may as well tackle all of it. Part of me says to do the water pump while it's right there, but another part of me says "knock it off" and "if it ain't broke..." but I guess I'll see what happens when I get in there. I got my new back bumper and brackets, too, so there's plenty to do if I do manage to get some quality time with the ol' girl this weekend.
I really think you should toss in a new water pump. I might have gambled on the tensioner...but a water pump is kind of a crucial item. ;)
I wasn't going to do the water pump on the 93 cummins motor...looked good from above, and there was no visible leak. I decided since I was in there I should at least pop it out and check it out. Good thing I did, for it was just starting to weep slightly around the bearing seals.
Yeah, the problem is once I have the water pump removed, well, the timing chain is right there too--and I already have all those parts on hand due to parts hoarding over the years. I think I might do the pump anyhow, though, and stop myself there... and then I'll be pissed when I have to do the chain. :D
Ain't that the truth....:D
Of course you realize I'm going to do the chain now. See what you did, guys? Next thing you know, I'll be saying "Well, the valve covers are off and the timing chain's out... what's available for camshafts?" :doh:
:D
