I know now that you can't use a hand-held on engine valve compressor on double valve springs. That kind really sort of lifts the outer spring when compressing it. The compressor doesn't affect the inner spring so it holds the retainer in place no matter how much you compress the outers. No bueno.
I tried taking an exhaust and an intake valve out of the 915 heads and in both cases the valve would slide down to where the groove meets the top of the guide and stop dead. Probably could fix that by filing the valve but those heads are at least 2nd on the pecking order so I just set them aside for now. There was little to no suction when I pulled the valve through as far as it would go so I expect they're worn out anyway. Also, the guides have not been cut down for long-lift cams. I'm pretty confident that the 346 heads have had that done already, given the .509 cam and the dual springs.
So, I've either got to buy a tool or get a borrow-tool from a parts store to see if they've got something heavy enough to compress the dual springs or not.
I stuck my head up on break and find that the riveted compressors aren't going to work and that is all the parts stores have.
Thinking about buying this Pardon Our Interruption
Can't say for sure if that's enough to do the trick. I really don't want to take them to the machine shop where they have pneumatic valve tools. Once that starts the road lead directly to spending a bunch of money because "well, since they're already there ...."
Of course there's a Summit branded version of the Proform tool, wonder if it's the same? Often there are differences.
Adding ... I've seen some posts of people with extreme valve pressures being unable to use that tool. I have no idea what pressure the springs on that head have, except to say it's a hydraulic flat tappet cam so the springs can't be over the top stiff - can they?
Adding more ... I reasoned that I've got 8 heads here that really need taken apart, evaluated, and disposed of one way or another, so I'd get plenty of use out of it. It might be here tomorrow, Summit and Jegs are both overnight shippers to me out of their Ohio warehouses.
Valve compressor will be here today, so hopefully more will be known tonight.
Noticed this on the crank, looks like it was stamped?
Last rebuilt in ...
I gotta look at that bearing again. Hard to believe it's standard size.
The other side - nothing you can catch your fingernail in
That was # 5. I stopped for the night before I started pushing pistons out.
This is where the valves stopped in the 915 heads
As close as I could get to seeing what's under the valves
No crosshatch left
The cam was installed dot-to-dot but it has an advance/retard bushing on the cam. The crank gear is adjustable so I guess this was just fine tuning? It might come in handy later so I'm saving it.
Not much else to say until I get the heads apart and the pistons/crank out. I'm running out of places to put stuff until I have a whole engine again ...
One head is apart. All guides passed the "pop!" test. The compressor rules once I figured out to try to center the valve stem in it even though it's damned hard to see it so it's a do by feel sort of thing ....
Yes, these heads have been worked a little bit
The others were the same, intake and exhaust. It all seems high quality.
Guides cut for positive seals
Somebody did a little grinding in the intake port, but not a lot.
You can see it a little better from this end.
So, unless the other head is messed up ... if I stay with the .509 cam (don't have to break in lifters) then I can just put this stuff right back together and run it. Everything is smoky and ugly but it was run rich as hell and wide open so of course it is. there's nothing going on a can of brakleen won't fix.
But, if I have to change the cam and lifters, then I will change to a single spring setup so it's easier to break in. I thought they were questionable when I pulled them out. They're rotating, no problem, but they looked scuffed to me.
Anyway I don't see a pair of aluminum heads or a big machine shop bill in the future for these, so that's a win.
Both heads are apart. I still need to clean and scrutinize both but they seem to be in similar usable condition.
I took some photos of the chamber in the 915 vs the 346. I don't think there was any real "porting" going on (yet) but they definitely did the 3-angle plunge cut yada yada that all machine shop worked heads used to get. That explains what looks like porting in the chamber, it's part of the plunge cut.
915:
346:
915:
346:
Valve sizes are the same, everything else is different because race car. The 915 parts look stock. They had umbrella seals on intake and exhaust.
I had to drive that valve out so it might need guides too. Probably did anyway after 60 years. It doesn't look like they've been apart.
Pistons/rods are coming out next
I noticed that the spring seat on the 346s is kind of eat up from the machining and suspect that is why they all had spacers there. You can see it in the photo above on the left side of one, the bottom side of the other.
I don't know if the 915s are worth putting any of my money in building them.
I will eventually check at least one of each of the 2 pairs of 452s to see if they've been worked to use big cams or not, but right now I'm going with the 346s to save $$.
I took a few photos of the cam/lifters
The lifters show their age
Heckuva reflection on the next one but it shows the tiny black dots. Dig that perfect circle in the middle. It's on all of them but not this obvious.
The cam's supposed to be a purple shaft .509. I haven't stuck a mic on it yet, but I'm confident that's what it is. Google didn't match the number to anything (yet), apparently it's before a change in part numbers.
Showing its age too
None of that will catch your fingernail but it ain't nothing. Time for a new cam?
Are the block cylinders stock or overbored?
+.030
I've got another 440 block - also +.030 and laying around in the gararge for 20 years or so.
I have a feeling I might be going to .040 before this is oever with.
Also, the crank is standard on the rods, +.010 on the mains. I haven't taken the crank out yet but did pull the thrust cap off and had a look. Same as the others, polish and go AFAICT.
Bearings are dated late 91, yearly 92.
It has a couple of these and other miscelleneous stamps
Ever seen this before? I guess it's the balance shop marking their territory?
The scuffs match - one caused the other, or I guess they were both caused in the same event. Whatever that was.
I didn't see any damage to the rings.
I'm finally getting over a cold so I'm ready to go back at it.
Currently I'm thinking that if a dingleball hone will clean up the scuffing in that one cylinder and the piston cleans up OK, then I'm just going to freshen this thing up and go with it. It was running fine when it was pulled, actually better than just fine, or at least I thought so. Yeah everything looks oily and nasty but it was a race car, they do that because they're supposed to be rich as hell. How many miles am I going to put on the car anyway, given the 15 or so years I've got left where I might be able to drive it?
The problem is not even a ball hone is cheap so I might just be throwing money away. Also noticed the finer the grit, the higher the price, so I gotta figure that out, and would need to select rings carefully.
'If I'm nearer the end than the beginning, then I've got to get going.' - Robin Trower
Lake Speed Jr. seems like a goofball to me but there it is. I don't think I really have much if any x-hatch left but there's no ridge at all, just a dark ring around the top where the rings never went.
If 3 or 4 things go right for me I'll be able get it going again with a ball hone, a little patience, and a set of iron rings and avoid the machine shop. Maybe. Hopefully. It'll definitely be more fun than loading it up and taking it to the shop, then waiting months for it to be finished.
Today's task after trying to fix the Duster's timing deal is to get the road runner on tires again, then on skates. Really looking forward to beating the hell out of that torsion bar one more time.
Once that's done I'm going to try to clean, organize, etc so the car is not in front of the door but the engine is, in case I have to move it out to hone, clean, haul to the machine shop, etc.
I picked up one of the cheap 3 stones of death hones while I was out. I'll give that a go first and may end up buying a ball hone to finish things. Since I'm just checking things out for now I wanted to spend as little as possible until I'm sure I'm going to be able to just reassemble the thing and use it.
