I opened up the floor a bit more in the pass side rear seat footwell area. Also cut off the middle of the exhaust at the straight part, right behind the trans pan, to get it out of the way. The retaining brace for the E-brake cable under the driver floor was then cut off the piece of floor I cut out yesterday.
After resting my back, I'll go out and wire wheel the areas where the subframe connectors land.
The center of the driver side floor was so distorted that I decided to remove the rest of it on that side. The areas the subframe landed got wire wheeled clean next. When I set the connector in place, there were still a few nubs that need to get cut off so it could sit flush with the under side of the floor around the forward end of the rear subframe. The connector is now strapped to a couple 4x4's to hold it in place for welding.
The plan is to weld it in tomorrow when my back is, hopefully, feeling better.
Got 'er dun.
Both ends are now mostly welded in place. I need to get the bottom corner edges of the rear connection cut back before I can make those long edge welds. With the floor out, I was also able to weld the inside of the front edge
The front outer seat mount bracket had a little tab on the end near the connector, so I welded that to the connector as well. The rear seat mount bracket was shorter and wouldn't reach, so I made a little L-bracket from a piece of scrap angle iron. I clamped the angle to the connector and welded the pieces together.
Having both seat brackets tied into the connector has made the entire area more rigid, even without the floor attached yet.
And for the record, I am very aware my welds look like crap. It's notably easier to weld this thicker stuff, and I'm really NOT looking forward to welding the thinner floor metal in. I'll be keeping a lot of grinding wheels, and flap discs on hand for a while...
Tomorrow I'll move onto the pass side floor prep.
All that matters is the welds are strong enough.
Plus you're welding with flux and haven't cleaned up those welds at all in the photos. They're fine.
If the weld doesn't look functionally solid, I just go over it again until it does. There ain't no stacks of dimes anywhere on this car unless someone else laid them down. 😅
The fuel pressure gauges arrived in the mail today. There's a 100 PSI gauge on an adapter on the inlet feed line and a 15 PSI gauge on the regulator body to measure the set output pressure.
For space reasons, I'll add a 90 degree AN adapter between the inlet gauge and the regulator before hooking up the hard feed line. I want to have both the inlet and return lines coming straight up from below the regulator, with the outlet line going out the side.
The mail also brought a bulk bag of 1/4"-20 rivnuts and and some 5/16" P-clamps.
Today started out with more rusty floor metal removal, on the pass side this time. Specifically, I removed the metal on top of the outer seat braces. Unfortunately, my grinder control was off a bit and I cut through the top of the front brace, but luckily the sides were still holding it in place. After getting rid of the sheet metal, I welded the cut shut and ground the top back down flush with the original surface. The rear brace also got a few gouges in it, but not as bad as the front brace. Those got welded shut and smoothed over as well.
Ooohh look! A squirrel!
Not sure how it happened, but next thing I knew I was under the hood looking at the seized coolant bypass nipple on the intake. First, most of the nipple got sliced off so I had room to work on getting the rest of it out.
Next I started grinding a relief on the inside of the threaded part of the nipple with a rotary tool. It was doing fine, right up until the chuck on the end of the flex line stopped holding the diamond burr bit and spit it out at 25k RPM. Thankfully I wasn't in the line of fire, but the bit didn't survive the impact with whatever it hit. When I found it on the floor, all the diamond material was shattered off of the shank.
After setting that battery powered grenade aside, I went back to the hammer and chisel method to collapse the threaded part into the middle of the hole. It took a while, but the nipple stub finally cried uncle and turned into a NPT taco and then popped into the intake. The T-stat housing was off, so the piece was simple to get out of the water passage.
With that done, I headed to Homey Depot to exchange the broken rotary tool for a new one, and then pick up a new nipple from a LPS on the way home.
After I got back home, I used a NPT tap to chase the threads in the intake. Then I installed the new nipple, with thread sealant of course.
Since I'm trying to reuse this factory 4bbl intake, I needed to address the severe pitting on the T-stat mounting surface. I used a RO sander with an 80 grit disc on it and went to work on it for a while. The result is not great, but more like probably passable. I also cleaned up the 180 degree T-stat itself as it didn't look too old or worn out, just dirty.
While resurfacing the gasket surface, I noticed a chunk missing from one of the T-stat housing hold down bolts. It appears someone had used too long of a bolt and tightened it so hard that it busted off a piece of the intake. That piece now probably lives somewhere in the coolant passages in the engine, unless it was found and removed right when it happened. When I bolt the T-stat housing back on for good, I'll be double checking the bolt length has clearance from the bottom of the hole. I'll also be using thread sealant on the bolt threads and keeping an eye on that area for leaks as well.
The T-stat housing on the other hand, was another story. It was rust pitted all over, inside and out. Since the RO sander was still nearby, I used it on the gasket surface for a while. Definitely better, but I'm going to want to keep an eye on it for leaks once I get the car running. Next, I picked at the rust on the inside to remove the big chunks, and then hit it with a wire wheel. On the outside pitting, I used a flap disc to bring the outer surface down evenly, so there wouldn't be an easy path for coolant to flow past the rubber hose. Once again, time will tell if this repair holds.
The front of the intake was all knicked up from manhandling the nipple and gasket surface areas, so I cleaned the area and taped off what I didn't want painted. I used more of the same gloss black engine paint from before and fogged that area with it. I also painted the T-stat housing at the same time. The t-stat gasket was toast, more like crispy burnt toast really, so I cut a new one out of some fiber-cellulose gasket material.
So much for getting the other subframe connector welded in today...
Pass side connector is in now. 😎
I do still have a little bit of welding to finish closing up the gaps at the rear of both connectors. However, I don't have room to reach them with the car on all four wheels.
Tomorrow I'm going to jack up the rear axle to give me the room needed to finish the connector job completely. I'll put the jack stands under the axle, out by the wheels, so the tension on the body should still be somewhat similar to being on all four wheels.
The last of the welds on the rear of the connectors are done now.
However, before I could start, I had to remove the huge mud dauber nests inside the rear subframes. The driver side was the worst, as there was a nest about the size of a baseball that had to get broken up piece by piece through the factory holes in the rail.
After that, I had to trim the split edges on the ends of the connectors and pull the floppy bits together with a C-clamp. The closest edges were tacked in place and then the larger gaps were then hammered together. The gaps were caused because the rear subframes were deformed from the car bottoming out hard.
Once all the welding was finished, I dressed up the welds with a flap disc and then gave everything a coat of rust reformer.
Today's goal was to get a floor piece able to set in place for a first test fit.
I don't have a spot weld drill bit, so all of the metal removal work today was done with a hammer and cold chisel. After a lot of work swinging the hammer, and involuntarily donating some blood, the outside edge and front pinch weld area were finally back down to the base metal.
After that the tunnel got trimmed back a bit more, and the rear seat hook was cut off the floor. With those last few pieces out of the way, the replacement floor was finally able to sit down in it's place. I still need to remove a bit more material at the rear of the rear seat foot well area before it will set 100% in place where it needs to go before welding it in permanently.
It fit close enough, so I traced the edge of the new metal onto the tunnel, and marked the holes for the seat belt bolts. One of the first things I noticed that the seat belt holes in new metal don't line up with the original holes in the car. The new tunnel side hole is about 3" forward of the original, and the new outside hole is also about 2-3" rearward of the original. I'll be installing aftermarket seats, so I'm going to wait to put those belt mount holes back in so they can be fitted to work best with the new seats.
With the new metal sitting in place, it's easy to see where the tunnel will need some metal replaced. Before welding the floor that tunnel area, and the large kick panel patch, will both be welded in first.
Got a late start so not much progress today. The squirrels weren't helping either...
I decided on a place for the fuel regulator, near the upper middle of the firewall, so I got to work on installing the mount for it. The bolt holes in the mount fit a #10 screw, so I'm using 10-24 nutserts in the firewall. Before the nutserts were installed, I sanded the area back to bare metal. There was an existing hole I was able to reuse, so I only had to drill two new holes and then slightly oversize the existing hole to fit the nutserts. After installing the nutserts I painted the area with rust reformer, since I couldn't get every last bit of rust out of the metal.
When I tried to install the bracket, the screws I had on hand were 8-24, so they started to thread in, but would slip as soon as I put any torque on them. I'll pick up the correct bolts tomorrow. I also will need to replace the two metric socket head bolts holding the regulator to the bracket. There's no room to get an Allen wrench between the bracket and the firewall, so I'll replace those with hex head screws when I pick up the other screws. I'll be able to reach the hex heads with a regular open end wrench to tighten them.
While I was there in the engine bay, I also sanded the top of the pass side inner fender. It had rust, bondo and some kind of that heavy, hard goop on it like there was on top of the hood. The rust had some really deep pitting, so I couldn't get all the rust out bottom of the pits. More rust reformer went on afterwards to protect the now bare metal and treat the remaining rust.
Before anyone asks, no, I'm not going to leave the engine bay black. When I'm ready to paint the car, the engine bay will be getting sprayed body color. That won't be anytime soon though. Getting the rust on the car treated, and getting the car in running shape, are both higher priorities over the cosmetics.
Today I got the correct screws needed for mounting the regulator bracket.
The hex head screws I found for holding the regulator to the bracket needed to be shortened, so I cut a few threads off and beveled the ends. That was the easy part. The hard part was getting my big fingers in the small space between the bracket and firewall to start the screws. I had to bribe one of the shop squirrels to do it for me. 🐿 It's bolted in solidly now, and clears all the other parts around it.
Moving onto the next nut, I pulled out the caliper I had soaking in the parts washer. Apparently the rubber piston seals didn't appreciate the mineral spirits bath. The seal swole up to about twice its normal size and came off the piston. When I touched it, the rubber just tore like it was made of tofu. Lesson learned, no more leaving rubber parts in the mineral spirits. A caliper rebuild kit is now on the shopping list. The pad retainer clips will need to be replaced as well since I found a crack on one. For now, I gave the caliper a quick exterior clean up and set it aside.
The caliper bracket casting also got cleaned up next. Afterwards I masked the sliding surfaces and then sprayed it with some high temp silver paint. I had some actual caliper paint on hand, but it's almost identical to the color of the wheels, so I chose silver instead for some contrast.
More squirrels, more random nuts...
I want to clean up the engine bay, mostly by removing as many of the holes in the inner fenders as possible. The holes were cleaned up with a rosebud type wire wheel in the drill. I'll need to pick up a piece of solid copper so I can use it as a backer when I weld the holes shut.
Since the battery is getting relocated to the trunk, I'm going to reshape the old battery tray location. There are rust holes through the inner fender where the old tray was, so that bad area is getting removed when I remake that section of the inner fender. The sharpie outline shows where I'm going to make a new, smoother, patch piece.
The squirrels dragged me to the rear window frame, so I got the grinder out and cut away the stuck screws for the trim clips. Lastly, I hit the whole area with primer sealer.
Those squirrels must have gotten a hold of some Adderall...
I wish I would've hunted and killed all the excess holes in my car before paint but I didn't. That's one of my lessons learned similar to you and the parts washer 😖
I figured I'd hit everything I can while I'm working in the area. I'm trying out a bunch of ideas I've gathered over the years on prior projects.
I honestly didn't know that mineral spirits would do that to rubber since I had never used it for parts cleaning before. I knew that carb cleaner would do that, so they must have similar chemistry I guess.
Dang I missed a lot, you've been busy. Great work!
These damn squirrels are slave drivers! 🤣
No turning back now...
I cut the rusty battery tray area out of the inner fender, keeping it in a large shape that would be fairly easy to replicate. Smaller cutout pieces would require more edges to weld and parts alignment.
Next up, I used CAD (cardboard aided design) to make the main replacement panel section from 18ga steel. This piece only needed two bends to fit it. The long bend I made with my metal brake, and for the short bend I just used the vise.
After a bit of back and forth fitting, the part fit well enough to tack weld it in place. Then I was able to make two filler pieces to fill the leftover gap near the shock tower. Once made, those pieces were packed in next. Then the entire perimeter was welded all the way around, except for the edge nearest the front. There's a gap there from an uneven cut that I need to make a filler piece for.
Tomorrow I need to find a thick piece of copper to use as a backer for filling those other inner fender holes with weld.
Already went thru two flap discs... 😆
Still have more to clean up, so I'm going to try a grinding wheels for a while to see if that's any faster for the rough removal.
Also just bought parts to overhaul the front brakes. Those parts should be here by the 5th. Have more parts to get soon, like seats and a few other big pieces.
