Dwayne Porter (known machinist) chimed in with the idea that this might have nothing to do with the lifter at all. Instead it might be something that's causing low oil pressure that's making the lifter seem collapsed.
I had 20 on the gauge, it shouldn't have been as bad as it was. Something's up. I'm going to put the lifter, pushrod, and rockers back on and hit it with the priming stick to see if it builds oil pressure next.
I found a fan too, one of the 18.5" 2-1/2" pitch ones. $100, and I'll need to buy a new clutch for it. That's more of a fair price, keeping it under $200.
I put the valve train back together, turned the pump with a drill, and I have over 80 PSI (working alone so I had to video the dumb thing)
The questionable lifter pumped up but it didn't hold - it bled right back off to nothing not long after I stopped with the drill.
Uncle Tony did an episode a while back about all the cam/lifter issues. A big part of the problem, according to him, NO ONE is remanning lifters. The only thing out there is "rebuilt" lifters. The problem arises if you take a worn part and re-machine it, the tolerances create a looser fit, allowing rapid bleed-down. You may have to try several to find a good on. Luckily you found it before it could cause cam damage.
I don't know if buying a new set will help if that's the case. There might be even more defectives in the new set. Or the next set might be soft or machined wrong and get eaten by the cam.
The hot ticket according to many on FBO is to use old lifters and have them refaced. That sounds exactly like what UT is warning against.
I dunno, having many in reserve doesn't help if it eats the first one I replace and scatters metal all through the engine :poop:
The things are so simple there's not much that can go wrong, and there didn't seem to be anything unexpected when I took that one apart.
I probably should take them all apart in case it's another lifter causing this one to starve for oil, but I felt lucky that I didn't lose any parts from the one I did disassemble.
This is the front lifter on the driver's side, pressurized oil flows from the back of the engine to the front, so maybe that's a problem? I was thinking about going ahead and putting it back together but I think I need to look into the oil flow before that?
Is there any way to test outside the engine?
At this point I would just buy new & put them in expecting good stuff, and add a prayer with the way new stuff seems to fail more often than not!
I don't think so. I was glad when I remembered that I could test the OP without starting the car.
You keep coming back to "new stuff seems to fail more often" don't you? :ROFLMAO:
That's why I'm trying to stick with what I've got.
I'm also hesitant to just throw money at it because that never ends in my experience. Look at how I've chased the cooling problem (that still isn't solved)
The issue that Tony alluded to concerned the internals. You can reface the contact surface, but there is no way to rebuild the internals. On that episode he did state that he ended up getting 3 sets to make 1 good set.
Having taken one apart this week I'm confused on what could need rebuilt in the internals. Maybe the inner piston would wear the inner surface of the lifter body? It doesn't move much, but maybe. That might explain the lifter(s) bleeding off in my case.
I need to hunt down that video to see how he figured out good from bad.
That is exactly what at least that one lifter of mine is doing. Start the engine and it rattles until the pressure shoots up, pressurizing the lifters. Shut the engine off, and at least this one lifter will bleed down almost immediately. Start it again, it rattles again until it pumps up.
UT did not explain how to tell if there's a problem before installing them though and I don't have the rest of my life to watch all of those videos and find out he never mentions it again :unsure:
One idea - pump them up with the primer then come back tomorrow and any that have collapsed are suspect - replace those. Repeat until I've got 16 that don't leak off. Maybe start with a new set of 16 and go from there. I'm kinda not happy about having to break in new lifters on the cam but that shouldn't be a problem. Right?
The next question is, what brand do I buy to replace these (Howard's) with?
Seems the Made in the USA lifters are all made by one company, Hylift, and it's not certain that they're not using remanufactured bodies and plungers. I knew these Howard's were made by Hylift so I had high hopes and you see what it got me :poop: So maybe it is certain they're using remanufactured bodies and plungers after all. :unsure:
