b-body-bob
I took the one lifter apart, didn't find anything that shouldn't be in there.
Uncle Tony did an episode a while back about all the cam/lifter issues. A big part of the problem, according to him, NO ONE is remanning lifters. The only thing out there is "rebuilt" lifters. The problem arises if you take a worn part and re-machine it, the tolerances create a looser fit, allowing rapid bleed-down. You may have to try several to find a good on. Luckily you found it before it could cause cam damage.The questionable lifter pumped up but it didn't hold - it bled right back off to nothing not long after I stopped with the drill.
I don't think so. I was glad when I remembered that I could test the OP without starting the car.Is there any way to test outside the engine?
You keep coming back to "new stuff seems to fail more often" don't you?At this point I would just buy new & put them in expecting good stuff, and add a prayer with the way new stuff seems to fail more often than not!
The issue that Tony alluded to concerned the internals. You can reface the contact surface, but there is no way to rebuild the internals. On that episode he did state that he ended up getting 3 sets to make 1 good set.The hot ticket according to many on FBO is to use old lifters and have them refaced. That sounds exactly like what UT is warning against.
Having taken one apart this week I'm confused on what could need rebuilt in the internals. Maybe the inner piston would wear the inner surface of the lifter body? It doesn't move much, but maybe. That might explain the lifter(s) bleeding off in my case.The issue that Tony alluded to concerned the internals. You can reface the contact surface, but there is no way to rebuild the internals. On that episode he did state that he ended up getting 3 sets to make 1 good set.
