I thought I posted about getting it back home.
Yes it's here. I've rebuilt the heater box, cleaned up and repainted the pedal box and parking brake mechanism. I shined up and repainted (as little as possible) the tail lights, backup lights, and front turn signals, and stuck the grille in place. I've got two rechromed bumpers but the mounts are still stranded at the body shop (among other things).
I've installed the brake lines and have a pile of parts to rebuild all 4 drums maybe this weekend. I had to do some trickery to get the brake line from the inside of the frame rail to the rocker but I've got it real close to running in the factory path and in the factory clips front to back.
See that hole at the top? That's where the brake line is supposed to pass through then go across to the rocker. No way was that happening with the frame connector in the way, but the way I ran it is the way it was to start with.
The fold-over clips on the firewall were all cut off and I didn't realize that before paint, so I had to go with some aftermarket clips on the factory lines from side to side.
Why is that upside down?
I had to make a command decision to run the fuel line down the inside of the frame connector and even then I had to cut a notch in the frame connector to get it through the torsion bar crossmember. I will also need to insulate the tubing from exhaust heat so that will go in one of those slip over insulation jobs like you would put over a plug wire. I've also got a driveshaft loop on the car so that should guard against a driveshaft failure taking out the fuel line and burning it to the ground.
I've got two fresh rechromed bumpers, but the mounts are still at the bodyshop pending paint. If they don't get to them before I have a chance to take a day off to go get them. Industrial strength Rustoleum will do just as good of a job.
I haven't put the trunk torsion rods back in, mostly because they scare me. It's a fear of either smashing a finger with the rod or having the trunk fall and do a guillotine number on me.
There is something weird going on at the quarter extensions. I bought the right gaskets for them but I can still see daylight between the quarter and the extension. It was not like that originally. I've got to do something there, likely closing the gap with some home weatherstrip tape.
Before
After (maybe?)
