A12 - time to get busy
I finally got all the tools. The 4-5" caliper was off about 0.025 so I had to figure out how to "calibrate" it, then off I went. It's a hassle getting the bore gauge and the caliper lined up to set the initial zero; I guess it gets easier with time. I was also screwing up in prior measurements beause I was looking for the max value when I realized I need to look for the min value to find the correct diameter.
I just took a few quick look-see measurements and it looks like things are better than I thought, but I need more confidence in my measurements before deciding if it needs to go to the shop or not. With any luck I can hone it with a new set of L2355s and iron rings and get things going again. There is little hope of finding a replacement at their (heavy) weight so I hope they still weigh the same today or that raises the balance issue.
Hopefully by EOD Saturday I can give a go/nogo on the bore.
I'm still unsure about the cam. It definitely has tiny black spots of something on the lobes and lifters so I should probably just replace it all, even if it's with another 509 design. Since it's a 440 with stall and gears I don't have to worry so much about streetability - I'll be looking for something that says "beware of dog" at idle and means it.
If I change the cam out I need to make sure whatever I choose is fine with a single spring because I don't need the hassle of switching springs back and forth to break it in. To be fair, a single spring will work with the 509, I expect they just chose those double springs to help with high RPMs at the track.
Double springs have steered me away from using a mechanical cam and I'm not looking at rollers because of the cost. I do hope to set up at least a rudimentary run stand to break it in no matter which way it goes.
One other thing - I tried passing my burnishing ball through the lifter bores and it really wouldn't even start in any of them. I could've drove it through but will wait until I get a ball home to deal with those and finish with the burnishing ball. Unless it goes to the machine shop, then only the burnishing ball is part of my job
