I put 2 wheels on the cut off tool to grind down the big blobs I made with my lousy welding!
It's the oil that does it. Brake fluid is mostly alcohol.I honestly didn't know that mineral spirits would do that to rubber since I had never used it for parts cleaning before. I knew that carb cleaner would do that, so they must have similar chemistry I guess.
Find a piece of 3/4" water pipe and hammer it flat. You can clamp it or you can use the other end like a handle to hold it in place where you can't. Um, I guess I'm too late.Tomorrow I need to find a thick piece of copper to use as a backer for filling those other inner fender holes with weld.
The 400 in my duster (same engine compartment as a 69 cuda) fit OK on the drivers side. It came with T-handles in all the VC bolt holes except the rear corners so I would sneak a 1/4" swivel in there to unbolt it.Yea, I'm going to return the ground rod. I realized it was just copper coated steel. I'll give that copper pipe trick a try.
I didnt realize I was out of grinding wheels, so I went back to the flap discs for the weld clean up. We were getting rain today, so I did the weld grinding kinda quick and painted the bare area to keep the rust away.
After that, I jacked the car back up so I could get started on the fuel lines. My jack stands were too short to have enough room to work with the long aluminum lines under the car, so I picked up a pair of the taller 6 ton stands from HF. Good enough now. The rear ends of the lines are now bent to shape, up to the firewall.
All that is left is to bend the lines around the blower motor, route the lines to the regulator ports, attach the AN ends and hook the lines up. After the lines shape and routing are sorted out, I still need to install rivets in the frame rail and firewall so I can secure the lines in place with P-clamps.
Pics will come later.
EDIT: I forgot to add that today I also ordered a two bolt aluminum brake master cylinder from the LPS, and got an A-body offset M/C adapter from Dr Diff. I'm planning ahead for when I drop the big block in the car. The 400 B block "shouldn't" need the offset adapter, but I plan on using aftermarket valve covers, so better safe than sorry.
You probably already know this but I found it easier to grind through the trashed side of the spot welds with a grinder. The way I thought of it is why waste time with a spot drill that you're going to end up having to bang apart anyway. No need to try to save junk,The outside edge was fairly easy, but the pinch weld at the kick up at the firewall was a bit more complicated. I had to use a ratchet strap to hold the pedals up out of the way.there wasn't anywhere to use the spot drill, so I was back to going between the cut off wheel and the cold chisel.
