I did this yesterday (it's finished now)
People freak out about clamping it. If you clean the car and seal both with wax/grease remover, put glue on both parts, wipe it around, and press the seal down really good, it ain't going anywhere. Promise. https://www.youtube.com/results?search_query=steele+rubber+products+videos especially this one
Another freak out is OMG don't get it on the paint. It wipes right off with a little wax and grease remover.
I also wondered why are we still doing this the hard way? Me, I had a trunk seal I bought about 20 years ago for $15 IIRC, so that's my reason. Yesterday I realized you can get a good quality peel and stick seal for $80. That is the way unless you're going to judged competitions.
If my work doesn't stick, I won't waste my time with this tube of glue stuff again.
A bunch of parts arrived today (Sunday? Guess so.) However, the 3/8" fuel line kit arrived without the ferrule to AN fittings. That fuel line kit will have to get reordered once I can get Amazon customer service to reply.
With the fuel filters and bulkhead pass-through fittings here now, I was able to finish fitting the nutserts in the mounting brackets. I also drilled two holes for the pass-through fittings. I'll weld the mounting brackets in place tomorrow after the paint dries.
A couple friends stopped by today to help me get those stuck wheels off the car. We tried a bunch of things, a dead blow hammer, a bottle jack between the frame and wheel, heating the spindle with a propane torch to soften up the powder coat, even dropping the car off the floor jack onto the wheels (with the lugnuts on loosely) and the cranking the steering wheel back and forth. Nothing worked. As a last resort, I tried removing the spindle nut and outer bearing, unbolted the calipers from the spindles and then unbolted the soft lines. With the bolts out, I was able to barely slip the caliper around the spindle just enough to allow the whole wheel, rotor and caliper assembly off the spindle shaft. If the wheels were any smaller in diameter, I wouldn't have been able slip the caliper past the spindle cabore.
Tomorrow I'll bring the front wheels to a shop somewhere to get the wheels onto a press to get the rotors off of the wheel center bores.
I'm sorry that's funny, pulling the rotor off because the wheel is stuck on it.
I remember having a battle with the well-known stuck rotor on an early 2000s ram. Yeah the wheel would come off but the rotor wouldn't. You tried it with no luck but there was a bottle jack and a lot of patience involved.
I got a local shop to press out the rotors for me. I asked them to also turn the rotors afterwards, but they didn't fall within spec. Minimum allowed rotor thickness is .940, and the first rotor we checked finally started to clean up at .915. One of the rotors also had a huge (1/8") crack in the outer bearing race. That same rotor also has a huge chunk missing from the outer edge that went into the path of the pads. So now I need new rotors, bearings and seals before I can roll the car around much. I'll still use the old rotors to hold the roller wheels on the car for now, but they're destined for the bin.
