74DartSport
has asparagus pee
And IIRC the big Moto units have a bushing in that top mount that is durn near impossible to find.
That's not really the case any longer. Even the classic "squarebacks" have usually been through the reman bin enough times that the marking is no longer relevant. I've seen a number of 63/65A remans in a 37A case, for example. The outer cases can be swapped William Dash Nilly with regards to their internals, which is exactly what happens at a remanufacturer. All the similar cases get thrown into one bin after the windings have been removed.Most alts have the amp rating stamped on them somewhere, at least they "used to" :doubt:
LMC Truck is now carrying '70s-'93 Dodge truck stuff, including patch panels, body parts, and trim.. I think they'll have the grille and headlight bezels.
cow..you might want to have a peak in the t-case...if they were plowin lots..good chance the chain is stretched...last thing youd want to have happen is have it poppin out of 4 in the dead of winter when you need it plowin
at the very least..keep it in mind for when you do the trans
