b-body-bob
You can never have too many pattern making ideas.
The adjustment slot for the old style was under the alternator. With the new ND style alt, the slot needed to be moved to the side. I know that I'm reinventing the wheel by making my own bracket. Rather than looking for something ready made online, I just felt like rolling my own for this.Now I have to ask the dumb question what was wrong with the factory brackets????????
I would've gone crazy trying to clamp/magnet it in place, but that's using your head.Next I sat the new floor in back place, weighted by setting bags of garden stone so it would sit as close to the flange areas as possible.
This reminded me that I lost two seatbelt points to the mini-tubs and it sure would be easier to weld those in now before the fuel tank and/or interior is in.Since none of the seat belt mounting holes line up with the new floor
I'm trying to get most of the under floor work done before welding the trunk and floors in."it sure would be easier to weld those in now before the fuel tank and/or interior is in."
I've been through it with water pump pullies, so yeah big and small blocks don't interchange. I might actually have something here that will work from when I was fighting the Duster overheating. I'll take your measurements and see what I've got.Ok, sorta got something done. I pulled the pulley off the 400 water pump to see if it would work on the 360. Nope...
First off, the WP pulley groove is offset halfway between two of the crank pulley grooves. It would fit with a 1/2" spacer between the pully and the pump flange, but then it would hit the electric fans, so that's not an option. When the pulley groves are aligned, the ODs hit each other. So what I need is a WP pulley that is 2" to 2.125" tall with a diameter smaller 6.25". Now I just need to find a pulley within those dimension limits.
