Now I have to ask the dumb question what was wrong with the factory brackets????????
The adjustment slot for the old style was under the alternator. With the new ND style alt, the slot needed to be moved to the side. I know that I'm reinventing the wheel by making my own bracket. Rather than looking for something ready made online, I just felt like rolling my own for this.
First thing today I pulled the alt bracket template off the car. I marked where it's going to get cut out at the middle of that big flat area. The long WP bolts and washers got painted while they were off. That's where I stopped on that while the paint dried
Next up was dealing with the front end. The header panel was removed, and the threaded holes were tapped. One bolt was stuck in the driver fender, so I still had to get that out. WD-40 didn't work, PB Blaster didn't work and hammering the bolt head didn't work. Lastly, I tried using a propane torch to heat the threads. This started to loosen the threads, but after a few short turns back and forth, the bolt locked up again. The next time I tried to get it loose, the welded nut inside the fenderbroke loose, and now the bolt is spinning loosely, while still being held in place by the nut trapped inside the fender. The bolt is going to need to be cut off, and a new bolt welded inside the fender. Not sure how I'm going to reach inside the fender to weld it yet. I'll also have to replace the bondo in the top front edge of the fender. The bondo there got cooked by the torch.
The crumpled valance was also removed, and I only needed to cut one bolt off. Luckily that one has easy access from each side, and I'll just need to replace that bolt when I install the new valance. All the valance mounting holes were tapped where needed.
The crossover nipple for the intake arrived in the mail today. It was installed in the intake with thread sealant. The crossover hose was then slid over the two nipples and two new hose clamps were installed. That's two more holes in the engine sealed up.
On the carb, I capped off three open ports, using some new rubber vacuum caps. Three more holes closed up now.
Then I measured the core of the aluminum dual fan radiator, which turned out to be wide than the opening in the radiator support. The opening needed to be widened by 3". So I marked a line 1.5" in from each side and cut along those lines to widen the opening.
When the radiator was set in place, the top edge was poking up a bit, but I won't know if it will hit the hood until the hood is cut and can close. The fans are going to be close, but I'll need to get a WP pulley and mount it before I'll know if there will be a clearance issue with the fans.
