That's some crazy work, I have made a couple of small brackets, but mostly out of sheet metal & a lot of bending.
Now I have to ask the dumb question what was wrong with the factory brackets????????
The adjustment slot for the old style was under the alternator. With the new ND style alt, the slot needed to be moved to the side. I know that I'm reinventing the wheel by making my own bracket. Rather than looking for something ready made online, I just felt like rolling my own for this.
First thing today I pulled the alt bracket template off the car. I marked where it's going to get cut out at the middle of that big flat area. The long WP bolts and washers got painted while they were off. That's where I stopped on that while the paint dried
Next up was dealing with the front end. The header panel was removed, and the threaded holes were tapped. One bolt was stuck in the driver fender, so I still had to get that out. WD-40 didn't work, PB Blaster didn't work and hammering the bolt head didn't work. Lastly, I tried using a propane torch to heat the threads. This started to loosen the threads, but after a few short turns back and forth, the bolt locked up again. The next time I tried to get it loose, the welded nut inside the fenderbroke loose, and now the bolt is spinning loosely, while still being held in place by the nut trapped inside the fender. The bolt is going to need to be cut off, and a new bolt welded inside the fender. Not sure how I'm going to reach inside the fender to weld it yet. I'll also have to replace the bondo in the top front edge of the fender. The bondo there got cooked by the torch.
The crumpled valance was also removed, and I only needed to cut one bolt off. Luckily that one has easy access from each side, and I'll just need to replace that bolt when I install the new valance. All the valance mounting holes were tapped where needed.
The crossover nipple for the intake arrived in the mail today. It was installed in the intake with thread sealant. The crossover hose was then slid over the two nipples and two new hose clamps were installed. That's two more holes in the engine sealed up.
On the carb, I capped off three open ports, using some new rubber vacuum caps. Three more holes closed up now.
Then I measured the core of the aluminum dual fan radiator, which turned out to be wide than the opening in the radiator support. The opening needed to be widened by 3". So I marked a line 1.5" in from each side and cut along those lines to widen the opening.
When the radiator was set in place, the top edge was poking up a bit, but I won't know if it will hit the hood until the hood is cut and can close. The fans are going to be close, but I'll need to get a WP pulley and mount it before I'll know if there will be a clearance issue with the fans.
Looking at my radiator hoses, neither of them are going to work as is. The top rad spigot and thermostat spigot are both for 1.5" hoses. The lower spigot are both sized for 1.75" hoses. Both of the hoses I have here are 1.5" ID, so neither of them will work for the bottom rad hose. Between the two hoses I had, there was enough length and bends to make up a hose that would work up top. Now I just need to get a hose splice tube to clamp in the middle of the area where the ends meet. It's not the best solution reliability wise, since it'll have an extra failure point, but it's what I have to work with right now. The parts are all new, so it should still hold for a long while. I hope.
I'll look for the correct lower hose at the LPS when I pick up the inner hose sleeve for the top hose. If I cant find the exact right one, I'll just get a couple that have the right ID, bends, angles and lengths to put together another joined hose like the top one.
I picked up a three pack of hose connectors and installed the right sized one. The top hose is all sorted out now.
I didn't find a suitable lower hose solution at the LPS I went to for the hose connector, so I'll check some other stores tomorrow.
After that I just picked up tools around the shop and cleaned the garage. The place was getting a bit disheveled.
Not a lot done today. I pulled the old starter off and checked it out. Sitting it next to the big block starter, the motor on the A body starter is about 1/2" shorter. The other geared head halves are pretty much the same. Probably for exhaust clearance I'm guessing.
When I welded in the battery tray area patch on the driver side inner fender, I gave the entire area a quick cover up coat of rust converter paint. The paint never looked right up close, so I sanded most of the area back to bare metal. There was a lot of stubborn rust deep in a number of places. I ended going through five tool batteries using a knotted whire wheel and a RO sander before I called it quits. I'll try to get the areas I couldn't reach when I lift the engine to replace the motor mounts. For now it just got another coat of rust reformer.
Today was just prepping the rest of the driver side to make way for the new floor. Not much to say, just more working on the spot welds and surface prep. The tunnel side patch booger welds were also cut away, revealing three layers of rusty metal in places. I left about 1.5" under the sharpie line I drew where the new floor rested. That way there's material left to join the new floor to the tunnel. As usual, after prepping the surface all the bare metal was coated with rust reformer.
More floor work today. Mostly fine tuning the fit between the body and the new floor. The tunnel was cleaned up more and exposed more rot behind the shifter. I'll need to make a slightly larger mid tunnel patch to cover that area.
Since none of the seat belt mounting holes line up with the new floor, I put tape on the body and wrote measurements on it so I'll know where to put the bolt holes in the new floor. The incorrect bolt holes will get patches welded in to close them up before the floor is installed for good.
When I sat the new floor in place there were a few places that need some fitting. Two diagonal dimples under the seat need the pre-slotted notches cut out of the subframe. The tunnel metal over the inner seat belt bolt, as well as the tunnel metal at the rear corner was trimmed to the marked line. It was cut away to allow room for the new metal to butt up to the tunnel rather than overlap it.
Next I sat the new floor in back place, weighted by setting bags of garden stone so it would sit as close to the flange areas as possible. I used a small scribe to trace the underside on the bottom side of the floor, pulled it out and then drilled the spot weld holes. A flap disc deburred all the holes afterwards.
Before welding the new floor in, I need to patch a spot below the door latch, that mid tunnel area and weld shut all the accidental slices I made while cutting out the old floor.
I would've gone crazy trying to clamp/magnet it in place, but that's using your head.
This reminded me that I lost two seatbelt points to the mini-tubs and it sure would be easier to weld those in now before the fuel tank and/or interior is in.
