Now that I think about reassembly the top of the dash is held in by 4 small bolts that go in at each end of the defroster slots, so that's not it!
So the Boy also reported he had no heat, so I checked that out today, the cable popped out of the clip on the valve on the inner fender, I do remember it was right on the edge to get the full throw on the valve, so I tried slicing a hard plastic tube to extend it fully into the clip, looked like a good fix, go in to move the lever & it was tight, so tight I ended up kinking the cable under the dash, just the job I wanted, more crawling under there, taking half the damn dash apart!20251114_154259.jpg
Now where did I get that cable, going searching in a while!
With things like that I usually try to squeeze some wheel bearing grease into it before installation. Then work it back'n'forth for a while, while adding more grease. Whether it helps or not, I don't know. But it gives me a little peace of mind.
I did something like that with the hood release cable (not sure what I put down it, WD40, or just plain oil?)
Anyway was thinking of oiling the new one.
I did see a post on the cables, mine seemed a touch long, I had it way back at the edge of the clip, that's what popped out. but was the only position I could get full throw on the valve.
In the post another guy said he had the same problem & put in a self adjusting cable clip, no part # or supplier, tried to google it & came up empty.
Bet Jass would have a part #, I miss you Bud.
Anyway I'll get pics if it's the same on this one!
WD40 will dry up over time, whereas oil won't. For more permanent lubing go with oil.
So after wasting 1/2 hour taking trim off the front of the dash & see no way to get the heater control out I crawl under to find 3 screws from the back!!!
So I fight with that for a while & get it to a position I can put the cable on the control.
When I lined up the 2 cables the new looked like it may work, slightly more cable cover on it? 20251123_142007.jpgGet it all layed out & same problem, at full open for heat the cable cover is just outside the clip.
20251123_145940.jpgOne of the comments on the post I found said you could rebend the wire shorter so I gave it a try, cable cover fully in the clip.
20251123_150425.jpgsuckycess, not a perfect bend but it works!
So for the hell of it I straightened out the kink, I probably just could have done that & rebent the cable at the valve, I stuck it in my spare parts box in the trunk.
Another shortcoming, rubber gromet ay the firewall doesn't snap in just layed there, I siliconed it in like the first one.
20251123_154533.jpgI did drip some oil & work the cable quite a while, not sure how far down it got, but it operated pretty smoothly!
Found another job, after the ride I didn't see that the retractor on the rear belt won't go back in, gotta pull the seat to get it out!20251123_154813.jpg
Seat back out, my old seat foams not doing so good......................20251124_140039.jpgGave that area a good clean up & while the vac was out I hit the front too. 20251124_141258.jpg20251124_140544.jpg
1st page of the sheet I threw in when my son took it to work20251124_140559.jpg
On to the retractor, pretty nasty in there, I had to pop the plastic off the rivits to get the cover off.......20251124_142117.jpgAt that point it did unlock & roll up, so I poured oil on all the outside spinning stuff & a bunch down the middle where the spring is, seems to be running smooth now.
I was just about to glue it back on when I noticed the holes in the plastic were smaller than the rivets, took a small screwdriver I managed to work it back under the rivets, one is perfect, the other a little beat up but even with out those it was on there pretty tight. 20251124_142938.jpg20251124_142928.jpg
All cleaned up back there & back together! 20251124_144817.jpgWonder if I could find or make a cover for the front retractor only thing not finished back there, missing both! 20251124_145002.jpg
I noticed this the other day. dash in the thin areas by the vents seems to be sagging, not sure if there's metal in there or just the pad? I could lift it a touch with my fingers? 20251124_145043.jpg20251124_145100.jpg
Prop something like a paint stir stick under it and prop it up slightly above where you want it. Then carefully apply heat with heat gun or hair dryer to soften plastic. Allow to cool and check it out.
So the other day I took it out for a ride to test the heater, didn't even get out of the garage, no blower motor now, didn't check yet hoping one of the wires on the control popped off?
Today I had my bro in law over to kill time while the ladies were at my sons wifes baby shower. was just gonna cruise the local streets till he says I've never been in a muscle car before, I detoured to my kick down test area & gave it a blast, this time it fishtailed violently on me, that was Fun!
But letting off for that I never made it to the chirp into second, maybe next time he said!
Took her out for the first ride yesterday, all went well no glitches I could pick up.
Ran into another car guy, the hometown show never got rescheduled last year, maybe she'll make a show this year?
Not my problem anymore, I think this was my last car, at 73 I'm afraid of leaving a half done pile-o- parts back there for my kids to deal with when I kick the bucket.
When I get bored I think about a duster, prices not in the stratosphere yet, just to give me something extra to keep me busy.
Those were pretty quick with the 340 right out of the showroom!
Found a good use for all that 1/4" tape I got by mistake, wanted to see what it would look like if I extended my stripe all the way to the front20260326_144227.jpg
I actually like the green outline, so If I ever get bored enough to do this, I will buy green pinstriping tape & outline it too! 20260326_144246.jpg
The shops back in action, Marks tranny started slipping & He ended up buying a motor with less milage & the tranny20260327_160235.jpgHis idea was to pull the cross member so he could pull it out the front with hood on20260327_160224.jpg20260327_162114.jpgGot that out but it was a struggle never go back without at least loosening the fenders, So last thing I helped with was pulling the hood, he's playing with the fenders now.
Don't think I ever had this much clutter when I was building the cars! 20260327_162104.jpgSee how tomorrow goes? 20260327_162120.jpg
Holy crap, He spent a good part of the day just getting the intake manifold off that thing, still trying to figure where to hook up the chains to the pull the motor, there's bolt holes in the back of the heads if he can get to them!
He was thinking of selling the motor, but with all the work required to put it back together it's destined for the junk yard now!
