I've heard complaints about the aftermarket "reproduction" trim rings in the past, but I've never run into it myself. There were repros on my Challenger when I got it but they actually fit pretty well. One thing that may be an issue (and only you would know, if you even do) is the width of your wheels. I can't recall if those are 14s or 15s, but Rallyes came in four sizes of which I'm aware: 14x5.5, 14x6, 15x6.5, and 15x7. I think each had their own trim ring, but I can't swear to it on the 14" wheels. I know a 15x6.5 will not accept the trim ring from a 7" wheel.
I mentioned it months ago before the front end was assembled. That being said, the blackout on both of my Valiants is just flat black paint, sloppily applied from a spray gun. It's nothing a'tall like undercoating or rock guard.Before you go any further, paint the core support black with stone guard paint. It's what I've found to be nearest to the slop that they used when new.
The antifreeze you need isn't specified necessarily for any cars, other than "literally every car in the world older than 1990". Look for "conventional green" and/or "ethylene glycol" on the label. Antifreeze is antifreeze, it all comes out of the same plant so get whatever's least expensive. Either buy premix 50/50, or use distilled water with full strength.So I'm looking around at green anti freeze & they come up with for asian cars, is this the same stuff I need.
my auto zone has peak & prestone max, any preferance?
I'm not sure what the solution is, but this is exactly why I hate raw aluminum on engines. It happens every time. Maybe try wiping it down and applying some wax on it? I wouldn't suggest aluminum polish because despite usually having some protection afterward, you'll have shiny spots here and there with dull aluminum elsewhere.Last but not least how do I stop this, carb is already getting puck marks from sitting out there????? View attachment 27324
