What you've got is a steel-crank, standard (LY) rod engine. Best thing you could've hoped to get in '74, really. The pad stamping would have an "E" on it were the engine equipped with a cast crank. Don't worry about the "special" head gaskets; most of the available ones have the openings for the larger coolant passages (which you might not even have).
Both HD (a.k.a. Six Pack) rods and the cast crank require external balancing. Mixing the two, to my knowledge, never happened, as it would've required even more offset balance on the converter and dampener. I've never heard of either such parts. The LY rods are the strongest factory rods for the RB engine; the "Six Pack" rods are simply heavier--they're not any stronger than the base rods in the years they were produced. It's been proven time and again. If you find a set of HD rods, sell them on eBay to someone that doesn't know any better. They're literally worthless for either performance or durability, and additional reciprocating weight is never a positive.
The actual compression ratio of that engine is between 7.6:1-7.8:1. 8:1 would be nearly miraculous, despite whatever the published specs are. Mill a ton off the heads (.060"-.080") to help correct this, and leave them alone other than that. Get a cam designed to maximize cylinder pressure at low/mid RPM, where the engine will be working. Long duration is absolutely your enemy here. Want a suggestion? Call a reputable camshaft company ("reputable" immediately precludes Hughes) and tell them what you're doing. Prepare to be underwhelmed by the specs. An Edelbrock Performer non-RPM would be good here, as would a stock factory intake. Anything with larger ports than those will be counterproductive on a truck engine, but if you've got a good dual-plane already you may as well use it.
You need a neutral-balance flywheel, obviously, that corresponds to your chosen bellhousing. Spend the money on a good clutch.
