Stretch
Cutting coils is not a good idea from a alignment stand point. You loose suspension travel. You also mess with camber/ caster/ toe / and Ackermen angle. Bump steer from the tie rod angle change is the biggest issue. The second biggest issue is the lack of camber/caster adjustment do to the ride height change. Proper drop spindles or control arms eliminate ALL of these issues! Money well spent in my book!
