olderigetfasteriam said:
My wife uses a power chair, just got a new one recently. We are watching this thread intently and appreciate your updates. Also, it is not easy being a sole caregiver. You have gone above and beyond. Well done.
for 32 years......its NOT easy
i will admit theres a few "tweaks" i would have done on this build if i were to do it again, but im kinda going for the overkill as i dont want it to be "hard pack" dependent..or anything like that, the adjustable length and width is kinda moot point but i wanted it to "kinda" fit ok on sidewalks, and into "wide" door frames, its not intended to go "indoors" but i felt the need to make it semi possible, the adjustable length now just seems silly, but i figure for trailer space and storeing it it might be usefull
all said i think for stability sake i basicly nailed it, with all that battery weight slung low, the big tires, the wide track and length this thing should be more stable than a quad, and smoother than a sport one at the very least....the only down side is a lack of front suspension...which....if i would have maybe swing armed the Z section of the frame it could have had suspension..its just impossible to know how the casters would take that kind of angle changes
had it not been built as an xmas present i would have taken direct measurements off of her so i could have tweaked seat position and angle to the points where she feels "neutral" and then built around that as it would have likely allowed for a lower seating position and possibly further forward...i potentialy could have done alot of minor tweaks on the fly, but at the same time.....its built to suit ANYONE at this point, even with her right leg gone from the cancer i still blasted cleaned and painted the entire right leg rest as well
if "sand" wasnt high up on the menu of things i want it to do...since shes not been on the beach since the summer of 88 the quad fronts were basicly a requirement in my head..tho i do belive one could get away with honda z-50 tires n wheels, heck swap the tires out for snow blower tires(same wheel size) and youve have some gnarly fronts that arent as wide/tall on a more common axle size which cuts down a load of issues in itself, everything from frame angle a lack of needing to z the frame the forks shrink a ton...it takes soo many issues out of the build it puts it more inline of being "easy"
"if" you want to build one..or want someone to buiild one let me know...luke did a full cad for me of a bunch of stuff for 2d cnc...and the one thing anyone wanting to do this would need would be the adaptor plate to come off the wheelchair hub drive to a quad wheel which i have saved at sendcutsend....heck with that alone you could toss quad rears on the back of pretty much any chair out there.......and it wouldnt take much to throw z50's on the front..just some new caster frames and slide the seat forward to clear em...cant vouch for stability tho
all of the "small parts" have been cleaned, the blacks been multi coated, the remaining parts too clean are the motors and gear boxes and electronitcs...otherwise its just a wait for more cure time and then onto assembly
so..tommaro or monday ill finish up the cleaning..looking to assemble tuesday..i need to hit the honda shop and see if they have any honda decals
