Can anyone ID this Transmission???
Dr.Jass said:
an aluminum case with a "PP" stamping and an iron tail, it's an overdrive. Period. No need to open it up.
I guess if P.P. says "PP" is an OD, I gotta believe it's correct ( I've never known him to err as of yet)
It's not the "PP" stamping itself... it's just that the PP stamping means it was a factory-installed transmission (not an aftermarket Direct Connection aluminum case). The only factory 4-speeds with aluminum cases were overdrive units. :)
If you measure the front bearing retainer, I'm sure you'll find that it's 5.125" outer diameter, another dead giveaway to an OD trans.
I'll check that tomorrow. Thanks for all the info, I had no idea how to ID this thing.
