Maximum Boost by Corky Bell. It's old and some of the information is a little dated, but it's still one of the mainstays on the subject and considered a must-read by many. Bell is very opinionated, though, and some of his opinions (such as water/meth being an absolute no-no) have been disproven as flawed at best.
Street Turbocharging by Mark Warner. It's broken down well, with each aspect of turbocharging broken down by subject into individual chapters. When it discusses fueling, it's usually related to fuel injection, but there's a good appendix at the back regarding blow-through carbs. It also has several examples of custom turbocharged vehicles in another appendix, ranging from a 10-second Mustang to a rotary-powered Datsun 510. It's got more modern information than Bell's ancient text. There are a number of very useful formulae in this book concerning fueling requirements (again, for EFI) and how to use compressor maps.
If you're going to buy one at a time, I'd highly suggest getting Bell's book first. Warner's will be a good one that builds upon it. I would definitely suggest getting both, though, and reading them enough times that you get to the "I remember this part and am gonna skip it" stage. There is way, way more information in these books than you'll digest in a single reading. Don't try to grasp it all on the first read-through. If you want to know this stuff, you'll read them again and again. I have... in fact, I still am.
There are literally no "how to build exactly the combo you want" books out there, so you have to grasp the concepts and work from there after deciding what you really want. Both books will help you in that respect.
Also, though it's main subject matter is on EFI,
Designing and Tuning High-Performance Fuel Injection Systems by Greg Banish has some great basic ideas about things like spark advance and air-fuel ratios, though you
will have to read through the process of working with EFI to fish them out. It does deal with things like tuning for boost or nitrous, too. You just need to sort of interpolate the ideas into terms of jetting rather than keystrokes if you're going to build a blow-through system. In my case, this book was invaluable, since my goal is to have daily driveability and (hopefully) economy as similar as possible to a new car, all while making maximum power under boost. That ain't gonna happen with a carb and distributor, which is why I've spend so much time on research.
Feets is on both Moparts and Theturboforums, and used to post here as well. Rather than contact him straightaway, I'd suggest you read through any threads he's posted about his build if you want to attempt to duplicate it. As I recall, his car ran 10s. It was featured in an issue of Mopar Muscle several years ago.
I wouldn't contact
anyone until you've learned a lot more on the subject and have some kind of combination other than "I want to run nines with a turbocharged big-block" in mind. Broad, generalized questions like that usually remain unanswered or draw the ire of people who could potentially be of big help to you. Figure out a general idea of what you need to achieve your goals. Is a stroker engine actually necessary, or are those cubic dollars better spent elsewhere? I think you'll find the latter to be the case. Consider this: Figuratively speaking, a 440-cubic-inch engine at 15PSI of boost is ingesting as much air as an 800-cube NA engine. After you've done some reading, you'll understand why that's not literally true, because you'll understand things like pressure and airmass ratios and total airflow in regards to VE, all of which are critical to realizing your goal. They're what horsepower is all about. Remember that boost, by its very definition,
is a measure of your engine's resistance to airflow. Twice as much boost does not equal twice as much airflow; boost is a scale of diminishing returns based on the engine's naturally-aspirated volumetric efficiency... so maybe there's more gain to be had by upsizing the valves your 452s, and then attacking them with the die grinder than there is in a $2,000+ rotating assembly.
Read the books. You'll start to use your head rather than your wallet.
