An expensive Beetle broke itself in my shop..
So now the issue is the rings. It’s largely accepted that Alusil cylinders can’t be re-ringed. However, people have had some success doing it by covering their three armed hones with green scotch brite, and using Sunnen AN-30 paste for no more than about 45 seconds per cylinder. If it were my car, I’d try this in a heartbeat. It’s a customer’s.. I’m tempted to try it, leaning towards it actually. But it would suck to eat all of this work as warranty and still have to charge him over $4k in parts just to put the right cylinders in if the crapshoot fails. I’d say my chances of success in re ringing cylinders is about 60% based on website testimonials. Before I decide anything, I’m going to get his oil tested and check the bores for roundness. No sense in polishing a turd. Especially when just the parts to put the stupid thing back together total well over a thousand. $300 for a set of head studs and hardware. $2k for the carerra pressure fed timing tensioner upgrade. $700 just to replace the breakage prone mechanical units. This doesn’t include gaskets, a million O-rings, possible valve job, cylinder seals, new rings, exhaust hardware, wrist pin bushings, stud removal, or godknowswhatelse.
Let me know if some of the photos in the posts didn't appear.. I believe my ipad (or the computer I'm typing on now) is up to some horsefuckery
all but the last post of pics worked
i was soooo happy when i found i had a steel liner in my bike that could have had that nikasil
Fixed It! Still can't figure out how to keep some of them from showing up sidewards.. Probably need to be more aware of which way I hold the potato. Whatever, at least I can add photos here without some stupid third party hosting site.. That should have gone the way of the dodo along with dial-up.
just pre rotate the pics with whatever software you like and then save them prior to upload and youll be fine
that's just it. I hate the extra step. I've taken the picture. I click on the little picture link as I'm typing, select it from my photo album and done. I don't want to deal with a website, or some extra software that i have to open, so that I can open a picture. Drag and Click. Done
Why not just hold the cam the correct way when you snap the pic? :naughty:
I don’t intend all of the photos I take to be put on the inter webs, and sometimes portrait frames something better than landscape, and vice versa..
