I finally got all the tools. The 4-5" caliper was off about 0.025 so I had to figure out how to "calibrate" it, then off I went. It's a hassle getting the bore gauge and the caliper lined up to set the initial zero; I guess it gets easier with time. I was also screwing up in prior measurements beause I was looking for the max value when I realized I need to look for the min value to find the correct diameter.
I just took a few quick look-see measurements and it looks like things are better than I thought, but I need more confidence in my measurements before deciding if it needs to go to the shop or not. With any luck I can hone it with a new set of L2355s and iron rings and get things going again. There is little hope of finding a replacement at their (heavy) weight so I hope they still weigh the same today or that raises the balance issue.
Hopefully by EOD Saturday I can give a go/nogo on the bore.
I'm still unsure about the cam. It definitely has tiny black spots of something on the lobes and lifters so I should probably just replace it all, even if it's with another 509 design. Since it's a 440 with stall and gears I don't have to worry so much about streetability - I'll be looking for something that says "beware of dog" at idle and means it.
If I change the cam out I need to make sure whatever I choose is fine with a single spring because I don't need the hassle of switching springs back and forth to break it in. To be fair, a single spring will work with the 509, I expect they just chose those double springs to help with high RPMs at the track.
Double springs have steered me away from using a mechanical cam and I'm not looking at rollers because of the cost. I do hope to set up at least a rudimentary run stand to break it in no matter which way it goes.
One other thing - I tried passing my burnishing ball through the lifter bores and it really wouldn't even start in any of them. I could've drove it through but will wait until I get a ball home to deal with those and finish with the burnishing ball. Unless it goes to the machine shop, then only the burnishing ball is part of my job
They make a small version of the three stone hone for wheel cylinders and master cylinder bores. One of those might work for the lifter bores. If you use one, stick with the fine grit stones and go slow and recheck the size often..
There's all sizes of dingleberries and even a caveman can use those. It's only about $25 for a 1"er.
It would be strictly glaze breaking - the burnishing ball makes them round again.
There must be a trick to setting up the bore gauge with a micrometer.
I'm happily moving along, watching the numbers thinking things look like there's no wear at all ... then I realize some of them are going past zero, meaning the hole is smaller than the expected bore, meaning my gauge is set wrong.
I did my best to get it right, calibrated the mic, lightly clamped it in a vise and set it to 4.350. Pretty much every time the gauge will slip out because I'm dealing with tiny surfaces on both parts. Then you think you've got it, stab the zero button, and notice the number changed just as you hit it so it ain't right. This is a digital indicator, and I imagine holding things in place while you zero the dial on an analog gauge is even more frustrating.
Any tips on getting that right are appreciated. I've watched several videos, none of them even mentioned how much a PITA zeroing the gauge is. They just do it and move on. That isn't working for me.
This is the first helpful tip - use 1/4" hose on the mic to help hold it Tips and Tricks for Setting A Dial Bore Gauge. Or I could buy $3000 worth of tools, but I didn't expect anything different at Goodson. They don't sell cheap stuff.
The way I imagine using the digital indicator should go, once it's zeroed the numbers should be negative in the bore (bigger than 4.350), then it should move toward zero as you get nearer the right place, and away from it as you pass the measuring point. The smallest number you see is your bore. It shouldn't be zero, and it can't be positive.
Now to go frustrate myself some more.
I had some 1/4" hose to use per the goodson site and that helped a lot.
The thing still wants to measure bore > 0 with the dial indicator zeroed at 4.35.
The measurement should always be negative because starting at zero=4.35, a negative number means the bore is oversize. That is because when the bore is larger than your zero, the moving end of the gauge extends, which translates to a smaller number on the dial. If the bore is smaller than your zero, the moving end of the gauge is pushed in, which translates to a larger number on the dial. So if you start at zero=4.35, a negative number tells you how much the bore is oversize, and a positive number means the bore is undersize.
I checked the micrometer @ 4.35 with a telescoping gauge and digital caliper, and the mic is at least as accurate as the caliper. I checked the indicator with the digital caliper with results as expected.
I tried using the micrometer to find absolute zero on the dial indicator, giving me the max diameter it can measure, then took readings and subtracted them from the max diameter. I still find that is telling me the bore is smaller than 4.35.
Nothing like using a tool without proper training to make a guy feel like an idiot.
The engine is +0.030 and stock a 440 is 4.32, so 4.35 the bore size, but is that the number I should be measuring to?
One thing's for sure, if you go back through my posts here and in my Duster thread you will find an idiot slowly turning on the light bulb over and over.
Honestly, one of the hardest things to learn about using mics and calipers is getting a feel for the light finger pressure needed for a consistent measurement. That feel is something that can really only be fine tuned with practice. For practice, you can try measuring different things a bunch of times over and over until you can get a feel that gives you a consistent reading. Lighter pressure on the clicker will allow for a finer feel than if it's tightened firmly.
Also, if you're getting smaller readings than the set value, you either have a deformed bore, or might possibly be setting something a little off. It's hard to say for sure without being there to get a feel for the tools you're working with. How far are you from Arkansas?
It has to be in the way I'm setting zero.
I've found that the gauge will start negative, move toward zero, then stop and reverse back toward negative. That's the way it should act, but it shouldn't cross zero. Mine ranges from positive 1-3 depending on the cylinder
If the starting zero is off the measurement follows so that seems to be the problem but I can't figure out what I'm doing wrong. With the 4" standard inserted the caliper zero lines up, then I set it to 4.325, which is 3 on one reading and two notches (.025 each) on the other. The third reading is zero.
I used 1/4" rubber on the caliper to help align the gauge in the caliper for zeroing, I made sure the rubber wasn't holding anything up. I measured without the rubber too; It's tedious but it turned out the same or close enough to call the same. With the mic set to 4.350 I measured that with a caliper to make sure they are within the same ballpark (+/- .0005 seemed to be the error range). I even looked at the head of a piston yesterday to make sure it really is +.030. I'm at a loss other than to keep doing the same thing over and over and hope I figure it out.
Hours were spent yesterday setting and resetting things and I was getting repeatable incorrect numbers at the block. I tried backward engineering it too, measuring the gauge's natural zero, using that to measure the block, the subtracting B from A and was getting the same kind of results.
As for the measuring end, I'm careful to only support the head when sweeping. Too tight of a grip and you can affect the reading. I kind of catch it in the crook of my thumb and move it. I think I've got that under control. I even have a comfy chair to sit in while I do it.
That reminds me of the time Jass offered me something but I had to pick it up. I thought he lived in BC, but no it's not that bad it's just the UP. :unsure:
I'm in WV, basically 3 hours from Columbus & Cincinnati, 4 from Pittsburgh. More hours than that for anywhere else you might have heard of.
I reset things for 3-4 hours yesterday, accomplished nothing. I squeezed the bore gauge a little tighter to confirm the thing would behave like I expect with a different starting point, and it did. That helped convince me I'm not losing my mind. It also showed me all 8 are pretty much consistent but I still haven't checked it rigorously to look for out of round or taper. (Actually it just occurred to me that I can go ahead and check that since the dimension doesn't really matter, only the relationship between the dimensions in each hole.)
I use the ratchet when zeroing the mic, so that shouldn't be a problem and I get the standard in straight and centered on the mic anvils. If the zero is the problem, I need an overall smaller measurement, which would mean squeezing it tighter. OTOH I could also be setting the gauge too tight when setting that using the mic. I guess that's the one thing I'm sure of - the 0.0350 is engraved so there's no problem finding that.
It could also be that one or the other of these tools is just junk. I've been cross-checking with a digital caliper but that's not accurate enough to help, and it might be junk too. You get more than one thing stacking up tenths and the next thing you know you've got errors. One thing I can be thankful of is that it wasn't wrong in the other direction so things look fine when they're really not.
Which leads me to a sort of a problem - since I started off screwing it up in some way that isn't obvious, how will I know when I've got it right that I don't just have it screwed up a different way? You don't realize how much a thousandth is until you try to adjust one of these things. I've started asking around trying to find a machinist to set me straight (and who might have ways to check my tools) but no luck so far. Our relatives are welders, HVAC, and electricians. Welder said if it's within a half inch hand him the hammer and it's good. :D
You might be onto something about possibly having a bad measuring tool. Can't really say without sending them to a metrology lab to check the calibration, which would very likely cost more than some cheap tools.
One more thing to keep in mind. Even a mis-calibrated tool can be useful to log variances from a set point. This is only if the internal mechanisms are just out of calibration and not damaged.
Even a mis-calibrated tool can be usful to log variances from a set point.
I'm seeing about 1 thou difference between the 8 cylinders. Who knows what that means relative to the bore sizes though.
I don't know man, the engine was running strong before. Yeah it has those wrist pins but it sat around off and on through the years and that might have been how that got started. But anyway, it had good compression, didn't smoke, etc. I'm leaning toward saying screw it at this point.
If it goes to the machine shop, it will end up being bored because that's just the way it is these days. I guess I'm trying to avoid going +.060 until there's no other choice.
Even doing just a basic overhaul is going to run into some money before it's over. The same .030 pistons/pins are $500 and there's no getting away from replacing those.
I saved myself all that craziness, just crossed my fingers & put the cleaned up engine back in, so far it's alive & kicking pretty good!
That's the plan for the 360 in the Barracuda. The seller said it ran when parked. 🙄 A comment which I don't put a lot of faith in, since it was said before selling the car to me. The car already has enough other issues to keep me busy, so I'll deal with any engine issues whenever something is obviously broke.
I was tempted to just stab it in and take my luck but I'm at the age it's not that easy to do and undo anymore so I tore it down. I don't think this one would've lasted too long with the stuck wrist pins, so that worked out for me.
I checked one bank of cylinders, at 90, 0, and both 45s and they were all within .0005 of each other according to this sketchy meter. So that bank seems to be round, we'll see soon enough if the other side is too, and that both sides make it through a second check.
I wish I could get a true measurement of the diameter though.
You could always use a snap gauge to get the bore size and then just measure that with your mic. A whole set of those gauges is only $20 at HF right now. That would reduce the chance of compounding errors in the measurement process.
I bought a set of those because I thought this was the natural use for them but the ends are flat so they're kind of useless for measuring a bore.
I have messed with them in this process but it's like using the caliper to sanity check but it can't be used for accuracy.
The ones I'm referring to have a slight crown to them on the tips. The larger range tools look flatter because they are ground with a radius that is supposed to clear it's smallest bore size. These have the crown, which is visilible in the pic above.
I rigged this up yesterday. I ran out of time to try it out so I don't know if it will hold the weight or not. I'll find out here in a little bit. I've been told this has worked for others. If it holds together I will trim it up and maybe drop a few tacks on it to stiffen it up better but I could also number the parts and take it back apart when I'm finished, for zero storage space needed.
I have a 904 here and it looks to have the same mounting points as the 727. Hopefully a small block 727 does too.
20261127_173421.jpg20261127_173437.jpg20261127_173523.jpg20261127_173658.jpg20261127_173706.jpg
I will say it might be a little bit scary in the vertical position. I'm going to lift it with a cherry picker and will keep it connected to that while testing things.
I looked closer at the telescoping gauges and yes they have a small radius on the end. I still get the same results though. The bore measures a tiny bit smaller than 4.35.
I've got another 440 block that I can barely get to but tried to check it anyway and it measures the same. So it's me or the tools or a misunderstanding of the proper procedure.
Also I noticed this - two big block 727s, should be the same right?
Look at the machined boss at the bottom of this trans
And look where it's missing from this one
I haven't followed up on the years because one of the trans is kind of tucked away at the moment.
