Ahh, that one. Well, if neither of those other two suggestions work, there's a witches brew that I learned in gunsmithing school. It works absurdly well for loosening stubborn threads. I don't member the exact ratios, but the ingredients are: ATF, kerosene and oil of wintergreen. If you need it thinner for faster creep, just straight oil of wintergreen. If you can't get it free with that concoction, at least it'll be minty fresh. 😁
I remember looking for wintergreen once before but couldn't find it locally. I'll keep that in mind when I get back to messing with it.
If it ends up going to the machine shop I'll just let them worry with it.
Online is probably your best bet to source that oil of wintergreen.
...Unless you have a goth apocathery in your neighborhood. 😆
I was flipping through some photos and noticed there is one piston hung upside down. I need to double check that. Seems like I remember that it's OK to hang them backward, maybe even an old school hotrod tip. But they should all be hung the same way.
Answers every question I never had.
It does answer the question "does this old wive's tale help or hurt?" "No"
BTW you don't need a mic to see the pin offset. There's no way to miss it.
I never really cared for DF. He comes across as a guy who just finished learning what he's about to explain to you. I know that's not true, that's just how it seems to me on TV.
The piston's not upside down. In the photo I looked at you could only see the arrow on one and it was upside down. I started cleaning and checking, and it turns out the passenger side always looks upside down. I checked them all to be sure they're all turned the right way anyway.
Also, from the HAMB "That damage isn’t usually caused by something getting in the bore. Thats an oil, mixture, ring, overheat, bearing play issue thats caused the piston scuff, I’d want to find the cause. You don’t want it to happen again."
The block's a mess, as far as being clean goes, but I got most of both decks cleaned up too.
I may put this one back together and send the other +.030 440 block I have to the machine shop.
I think if I could buy a 440 crate engine for the cost of a BPE 360 I'd consider just buying one and get it over with. I looked into that when I was thinking about a crate for our Duster and all I found were race strokers at about 2x the price of the BPE 360, and I decided the BPE was too expensive, so there.
Based on that quote from the HAMB I guess it would be best to do some measuring or take it to the shop.
You can't get these at Harbor Freight
I will need a 5" micrometer if plans are to measure the pistons but those don't come in a kit. I don't know why I would measure the pistons though because you can look at them and tell they're not worn (still need to check the ring grooves). Then it seems like I would just use the snap gauges on the mains and rods, so 3" is large enough.
Knowing me I'll probably end up buying the 6" set so they match the snap gauge ranges even if I never use it on anything but a mopar.
On ring grooves - the rings weren't tight so I think that means I'm good to go. If not, what's the tolerance on them? I know the ring sizes but haven't found anything about the groove width yet. While I'm spending I might look into a better set of feeler gauges, using the all on a thumbscrew kind I've got can be a pain when you have to start stacking them.
Let me know if you can think of anything else I need for now.
Since it's amazon and shipping cost isn't an issue I ordered the bore gauge yesterday to get going with it. If I even make it that far. I found a UT series on "your first at home engine rebuild" or something like that where he talked about checking for taper and round with a used piston ring. Common sense when you see it but I hadn't thought of it.
Yeah accuracy is in the can but it's not like I'm a trained machinist using Starrett tools anyway. I think my concern is going to be more about relative measurements and less about getting things perfect.
Mitutoyo or Brown & Sharp are also really solid brands. I'm not a fan of the really cheap chinese off-brand stuff. In my experience with both quality and sub-par measuring tools, most of the cheap ones have a poor tactile feel in the mechanism. That can cause some misleading feedback when you're trying to get a precise measurement.
Well we'll see if I can get a reliable measurement out of it today. If I've got to spend multiple hundreds on tools I might use 3 more times and still not be sure I'm even doing it right I'll take it to the machinist.
I watched a video about ball vs three arms of death hones, where they guy finished as good as it was going to get with the 3 arms of death, turned to the camera and said "But what do you do when you've still got low spots that the hone doesn't touch and it makes you worry?". Then he picks up the ball hone and does a few passes "Do this". My man.
I'm alone today and tomorrow so I hope to know where I stand on the block before the weekend is over.
So I got the bright idea to just check the current ring gap thinking if it would give me some idea of how much wear there is. I checked the scuffed cylinder and 3 others alternating holes side to side so 6, 2, 3, 7.
From the Senatore engine book, the gap factor is .004, 4.320+.030=4.350 * .004 is .017. From google the stock specs are .013 to .023.
The best here was .025, the worst was .030 (the scuffed cylinder). Of course the rings are worn - the ends weren't square to each other and once I figured that out things got a little better but based on this hillbilly test, I've either got worn out rings and/or worn cylinders.
The bore gauge is out for delivery so if I bought the right thing I'll have a better idea about it after the mail runs.
I think I can say I know what caused the scuffing now - stuck pins. The one next to the worst scuffing is blue. 2-3 others are stuck and look like there's varnish on them.
The mains have some fingernail catchers in it so that's going to need at least polished, probably cut 10. The two rear main bearings are showing some copper but they're not worn through or even near it.
I didn't realize the bore gauge worked like a snap gauge so you need a micrometer to use it. I tried using a caliper, didn't work, but I measured it as best I could. Then I took readings in each hole, subtracted that from the measured distance to get the bore size. The sizes were consistent but I hope I measured it wrong because I averaged them, leaving me .0065 over the expected bore size 4.350.
I'll know more once I get a 4-5" micrometer (Tuesday). That will also let me measure the pistons to the limit of the tool's accuracy ...
If I start getting into a different piston size or make, that's going to involve rebalancing, making the crank and rods less usable without mods. There's at least two big chunks of mallory metal in the crank right now. I guess it's easier to drill that out for lighter pistons than it would be to add it, and I've got a set of unmodified AFAIK rods that were on a cast crank engine.
An interesting point - a +.040 L2355 is crazy expensive compared to +.030 and +.060 (483 vs 742 vs 584). But then just going by price and bore size, pretty much every other brand is more expensive than that.
When you get the micrometer, dial in the measurement and then lock it in place. Then zero the bore gauge using the mic.
I've always either slapped them back together with new rings bearings and gaskets, or took everything to the machine shop and let them figure it out.
This figuring out which way to go by measuring things is all new to me. Tools used to be expensive so I got by with a torque wrench, a ring compressor, and a Motor manual.
I'm a parts changer, the biggest thing I did with the motor was go to stock rockers & put in new pushrods.
Opened em up, checked tork specs & cleaned, oh yea I did new freeze out plugs!
First car was rebuilt shortly before it was parked, texas car was worked at some point in it's life, it had30 over pistons, when the price of rebuild went from 4k to 8 k I decided to take my chances, so far it hasn't blown, just has to last till I sell it, I don't beat on it too hard so with a #'s motor I'm hoping it will survive!
I was working in the field at the beginning of the end of things being rebuildable. There was half as many people here and 5x the number of machine shops.
Now you're at the mercy of the one shop that's barely within driving range.
