TBH I'm tired of working on it. It's started a small coolant leak - I haven't looked it up yet but it looks like the Magnum water pumps uses a heater hose nipple that has an O-ring so it plugs into the water pump and an attaching bracket/bolt holds it in place. If that's right, the O-ring is leaking.
That pipe is such a common issue that we stock it. The best of luck to you should you attempt to remove it, though... they're usually corroded solid. I don't think I've ever sold that pipe without a water pump, or vise-versa.
Come to think of it, I probably have that pipe lying around because I'd bought one for my own Dakota. I have a new water pump, too, but it's the earlier bolt-on pulley style. There was nothing wrong with the pump on the truck, but I'd planned on doing the timing chain and switching to underdrive pulleys (as a fuel economy move). Some of that stuff is still around somewhere, I'm sure.
There are so many grounds on the truck that the FSM has a separate section to identify grounds and their location. Splices too. All the systemization and detail in the wiring diagrams is a blessing and a curse. I never did find a "big picture" wiring diagram like you find in muscle car era Mopar FSMs.
Your brain would melt trying to trace anything in a "world view" wiring diagram of that truck. I doubt one even exists. All the options you might not have would still be cluttering up the diagram, with Durango shit thrown in for good measure.
Obviouly, things got a lot more complex after the musclecar era. The AM/FM/cassette in my Challenger has five wires; there were 14 going to the radio in my Dakota. The wiring in my Imperial--an '82, mind you--is so ungodly there's literally an entire separate wiring service manual for it
in addition to that of the other J-bodies. You follow a wire until you get to "Refer to Imperial wiring manual", then go to that one. You finally find the other end of your trace only to learn it then directs you back to the basic FSM. Fun stuff.
Oh, yeah--the Imperial's separate wiring manual is on blueprint-type paper about the same height as an FSM page, but three times wider. I keep them rolled up in a cardboard tube labeled "Dead Sea Scrolls" since they were almost as hard to find, are just as fragile, and to this day remain only partially deciphered.
