I looked around when I went out to the truck today and found that none of the front end hardware was cleaned up yet. That ended up burning up a LOT of my time today. The heat blisters on my finger tips are an unpleasant side effect of standing in front of the wire wheel far too long. After everything got cleaned up and painted, I started putting the rad support on the front. All the pieces needed a bit of persuading with a hammer here and there due to all the prior damage. I'm not swapping out the fenders at this time, just the hood for now.
After I had the front end pretty much bolted together, I started sanding the front and driver side edge of the hood as well as the upper part of the driver fender. All the bare metal got a coat of grey primer for now.
I tracked down the wiring diagram in the FSM and located the connection points for the tach power and light wires. I'll look for a ground wire attaching point close by under the dash and put the ground wire there. Pin 21 on the firewall connectors should be the tach signal wire, but if it's not or it's not there then I'll pass the green wire through the firewall using one of the existing grommets. I'll be adding male and female spade connectors to the four tach wires about 6" from the back of the gauge. That way I'll have an easy way to pull the tach without having to run down all the other wire ends. I didn't get all those wires hooked up today, so I'll have to finish that tomorrow.
Next I put the radiator back in place and bolted it down. I cleaned up the hose clamps and rad hoses and checked them for fit. There was enough excess hose material on three of the ends that I was able to cut away the deformed rubber there. The lower hose at the rad wasn't long enough to cut, so I left that end alone. Once the hoses were on and clamped down tight, I mounted the fan on the water pump.
Now that everything (but the battery) was hooked up, it was time for the oil and radiator fluid to go in. I put five quarts of 5W30 in the engine and I have another one standing by to allow for the new oil filter. The radiator fluid started going in next, but wasn't quite as uneventful as the oil. Shortly after I started filling the radiator, I heard fluid leaking out from below. A quick look pinpointed it as coming from the missing petcock at the bottom of the radiator. I had forgotten to replace it after the original one fell apart when I originally removed it from the radiator. I couldn't find a spare lying around, so I used a standard 1/8" pipe plug for now. Once that was in place, I added about four gallons of radiator fluid to it. With the upper reservoir, it's supposed to hold another quart of fluid, but I haven't bolted that on yet.
Lastly I put the battery in and hooked the cables up to it. Before trying to crank it over, I pulled the distributor plug so it wouldn't fire the coil just yet. I cranked it for about a minute so the oil pump would get a chance to fill the oil galleries without the engine running. There's engine assembly lube on all of the moving parts, so they have that to keep everything lubed up until the oil can get there. Next I turned the electric fuel pump on to prime the fuel system and let me get a reading on the gauge on the fuel line. The fuel pump was sounding different than I remember, and quite a bit louder than normal. The fuel pressure gauge wasn't registering anything, so I turned the pump off. I disconnected the fuel line going into the filter and it was dry. Then I checked at the line coming out of the fuel pump, it was also dry. The fuel line going into the fuel pump was also dry. I took off the gas cap and used an air nozzle to blow into the hose coming from the tank to clear out any obstructions. I could hear air rushing into the tank, but it wasn't gurgling or splashing anything at all. I had two gallons of gas in a can so I added that to the tank. I tried blowing air into the hose again and still didn't hear any bubbling or splashing going on. It's already sundown, so I'll have to get some gas to put in the tank tomorrow.
I did manage to snap a few pics of the engine in place and just about ready to go, as well as a pic of the new tach in the instrument panel piece that I made for it.
