I'm not talking about weird stuff either, just basic parts like oil pumps, fuel pumps, starters, alternators etc. for the Dodge and the Mazda.
Dude, I manage a small independent parts store, and I assure you: That
is weird stuff, especially oil pumps--which rarely fail.
Anything for a '75 Dodge W350 with a 440 is weird. 440 trucks were never common, nor were 1-tons prior to the diesel explosion of the '90s. You're the only one in his customer base that owns one, much less plans on regularly using it. You realize the big-blocks went dodo 39 years ago, right? Nobody with any business sense is going to stock those parts. My friend Kevin's fuel pump died a couple of months ago whilst cruising in his '71 Charger R/T. He called like 25 parts store, and nobody had a fuel pump for any 440 application on hand. Mind you, he lives in metro Atlanta, GA--approximate population,
five and a half million people.
As far as the Mazda, if it's more than five years old and doesn't interchange with a Ford, other than brakes I wouldn't stock it either. Hell, Mazdas aren't common enough that I'd stock much for one regardless of age.
Simply put, if you think you're going to need that stuff you should buy it yourself and keep it on hand at home. "But I haven't got money to spend on something I'll potentially never need," you say?
Neither does he. He has employee wages, building payment/taxes, utilities, a franchise fee and probably a $30,000+ parts bill from CarQuest--
every single month. CarQuest charges a 2% finance fee on balances over 30 days--$600--which is probably a week's worth of wages for his top guy. The only parts he's going to stock are ones that turn over regularly. Every part on his shelves needs to pay the rent on that shelf spot. If not, back to the warehouse with it. Let them sit on it.
To give you an idea, other than the thermostat and maybe exhaust manifolds, I don't stock a single gasket for an LA-series Chrysler engine. Why would I? They've been gone for 25+ years, and other than the oddball beater or special-interest application, people don't drive them anymore. Keep in mind, I have eight of 'em myself, and Stretch has at least three more (we work at the same place). I
might have the exhaust gasket because it interchanges with the Magnum engines, but even those have been gone for nearly 15 years now. Knowing that it does not make good business sense for my employer to stock a pair of valve-cover gaskets for such an old engine, I keep a set in my garage.
It's part of the, uh,
charm of driving vintage cars. They're inconvenient. It doesn't make good sense from just about any standpoint except maybe roadside repairs, but even then--when something breaks you've either got a spare on hand, or you wait. That's why the Valiant got all new front suspension parts and brakes, and both the Challenger and Imperial will have the same. Our warehouse didn't even have the tie-rod sleeves on hand for the Valiant. I had to wait for
them to do a Moog stock order!
As far as the 440 starter goes, your local CarQuest probably has one. Part number 17466, the original application being the Magnum V6/V8. It's a bolt-on, with both higher torque and higher starting RPM. Lose the cable adapter, though--it's too close for comfort on the later B/RB blocks with the external ribbing. Pop off the plastic cover, remove two nuts for the adapter, and install. You may have to spread the two terminals on your positive cable, but it will go.
Don't open the box at the counter, just buy it and leave. That way, they won't know it's the wrong core when you return the ancient "ruh-ruh-ruh" starter in the same box.
Oh, and get a set of alternator brushes to keep in the glove box. Standard part number is CX1T; they should be able to cross that at CarQuest and order you a set--it's something cheap you can buy from them next time you're there. New brush holders are even included. Unless you've got the big Motorola 100A unit, 99% of classic Mopar alternator failures are the brushes. They can be changed in 10 minutes with a Philips-head screwdriver on the side of the road. :dance: It's the best $10 you can spend (locally) on roadside preparedness.
