Should I cut away the padding above the speakers?
The REM stuff used to have knockouts for the speaker openings. If they don't anymore, then yes, cut out the insulation in the area of the speaker openings. Don't use the package tray as a guide, use the sheetmetal.
Crap, more bad.
Read the header instructions & it says I have to cut a linkage brace, overlap it 1/4" & weld it back & install the rod upside down, that does not jive with all bolt in installation!!!
View attachment 26292Now my rod is barley into that support, I checked up top no slack there? I'm thinking of hanging the header to see, but I'm sure they have this all mapped out?
TTi
insisted I needed their modified countershaft for my 4-speed car, but the stocker cleared just fine. You might get away with just flipping the swivel to the top side, but the only way to know is to try it. Make sure you've got the starter and positive cable installed before you start trying to install the header. It's a real pain after the header's in place.
While I'm crying the blues, how the neck does this extender come off, the pulley is loose & can move a bit, when I turn the extension the pump turns, is there a fastener down that middle hole???????
View attachment 26293View attachment 26294
It just taps off. The only thing holding it on is "galvanic" corrosion between the steel pilot on the pump hub and the aluminum spacer itself. It might take some beating, but there's no fastener other than corrosion.
Find and use a blade that fits this:
Clutch fans are quieter in operation (often dramatically so) and net better fuel economy and power. The clutch you've got there is called a "torque limiting" design; they also make thermostatically clutched units. The thermostatic ones are a little more efficient, but it's not likely worth the extra expense over what you already own.
As far as blades go, they were made in 5, 7, and 8-blade varieties. Any of them that fit your shroud (if you have one) should work. I prefer the 5-blade fans used on cop cars and trucks. A lot of that is go-fast consideration, but they don't cool any differently than the standard 7-blade units. If you can't find a blade, let me know. I'm pretty sure I've got extras. With 12 or 13 engines lying around, I certainly should have.
Note to future Rusty: Fan clutches contain a viscous coupling fluid that can leak out over time. They should always be stored face down (sitting on the fins, bolt holes up).
