Couldn't find the old pics, seems the whole folder with the other rebuild has gone a wall, not even sure I had one of that but I'd swear the flex plate had the starter teeth on it?
Any way the marriage went well, after a stupid start, I laid out all the bolts & thought I was missing one from the top center, dig through a bunch & did find one only to then look at the tranny & there's no bolt hole in the bellhousing at the top!!!!!!!!!
The torque converter seemed to go all the way in on the first roll, I even pulled it out again & did it over, never felt 2 separate moves, but it was way in so I decided to see if it mated up ok & it did.
snugged down a few bolts & then checked for specs, tranny to motor was 28ft. lbs. I think, set those & then went to the converter bolts, started one & found the next one didn't line up, removed it, spun to the next hole & tried that, now all 4 line up, put on the thread locker & torqued those down, 21 is hard to read on the old wrench but I hope there all close to that!
With the tranny on she's got a natural lean down at the back, tilt adjustment is near center so I can get more if I need it.
now I have to extend the jack & see if & how much I will have to lower the front of the car?
The braces gave me a baby fit, I finally realized they go to 2 different spots on the tranny!
Have to locate the 3 small bolts for the bottom cover plate, now my homemade tranny table is the safety net, I trust it less than the bench!
There were no specs for the braces so I went with the same 28' lbs?
The torque converter seemed to go all the way in on the first roll, I even pulled it out again & did it over, never felt 2 separate moves, but it was way in so I decided to see if it mated up ok & it did.snugged down a few bolts & then checked for specs, tranny to motor was 28ft. lbs. I think, set those & then went to the converter bolts, started one & found the next one didn't line up, removed it, spun to the next hole & tried that, now all 4 line up, put on the thread locker & torqued those down, 21 is hard to read on the old wrench but I hope there all close to that!
