Why it's called a "PowerJoke"
A friend of mine stopped by last night, and as always the case with him, the talk turned to diesel engines. In this case, we got on the subject of the older Ford PowerStrokes, meaning the 7.3L and the 6.0L specifically.
The fuel-filtration system is so piss-poor in those trucks, that if you don't change the wildly-expensive filters at the recommended intervals, particularly if you live in a cold climate, you risk blowing off the ends of the injectors. Apparently, they don't like steam very much when water gets in the system.
The secondary filter is available in the aftermarket, but the design of the cap is different, as is the filter itself. Why? Ford patented the OEM filter, and to this day it's a captive item. Ford would not warranty destroyed injectors if you used an aftermarket filter, because even though it fits, it doesn't work the same as OEM. This came straight out of the mouth of a Motorcraft exec. Remember, this is the company that gave you the "permanent" air filter on the Focus... it never needs replacing! Price one sometime--it's a captive item, too--then explain to the customer that apparently it never occurred to Ford you might live 15 miles down a gravel road and have to follow someone once in awhile. Morons.
Running synthetic oil, particularly at extended intervals beyond what's recommended in the owner's manual, is going to cause you problems, especially if you work the truck hard (also verified by the local Ford dealer). You cannot run AMSoil for 25,000 miles in this engine like they will tell you you can. Yep, oil changes are pricey but they're still cheaper than a new engine or even replacing injectors.
The oil-pressure gauge in your PowerStroke-powered truck will read in the "Normal" range with as little as 4PSI in the primary oiling system, meaning the one that's feeding the main bearings. Pretty scary in any engine, but a compression-ignition engine?!. Yikes! This was verified using a mechanical gauge and two different senders in the shop where he works. That's 4PSI lower than the idiot-light pressure switch in a gas-powered Mopar of any stripe. He referred to it as an "idiot gauge"... "By the time it tells you there's a problem, you're already completely f__ked."
By early 1997, the 6.0L PowerStroke had caused over $75 million in warranty claims to Ford. Getting out of their planned light-duty V6 "F150" PowerStroke cost them another $75 million to buy out of the contract with International/Navistar. Why do you think they abruptly cancelled the 6.0L and missed months of sales? Why else would they design their diesels in-house now?
Why the hell would you design valve-cover gaskets that have electrical circuits running through them (this I already knew)?!
Any major work and some of what one would consider relatively routine, requires removing the cab of the truck. "I can't tell you how many times guys have pooped their pants when I told them the labor charges because I'd have to lift the whole freakin' cab off the truck." If you've never seen a local, small-town dealer try to remove the diesel engine from a Ford ambulance, pack a lunch and bring a Coke... in fact, pack a few meals, because you're going to be there a couple of days.
Say what you want, give me your anecdotal evidence to the contrary, and tell me about what you've read on the internet. This dude is in a dedicated diesel shop with customers from all over the country 10+ hours a day, 5 or 6 days a week. The man bleeds diesel fuel. For the record, in the gas world he's a die-hard Ford guy... yet he told me the Super Duty, regardless of engine (gas or diesel), is a freakin' junk bucket compared to a Dodge of the same year. That was one he really did not want to admit.
There was more, but I was getting rather inebriated and bored with that topic, so we moved on to the DuraTrash for a couple of minutes and then went back to gas engines.
Actually, the common rail cummins engines have electrical circuits in the valve cover gasket. Those circuits are basically trouble free as far as I can tell, unlike the ford stuff.
Why would you have electrical circuits in the valve cover gaskets???
My neighbor a coupe doors down has a power stroke 7.3. He must change the oil every month in that thing...fuel filters even more regularly. I go down and talk diesel motors with him when I can....he's a cement truck driver so knows diesel motors. He always has some new bitch about his powerstroke. I laugh and tell him he needs a cummins.
I was listening to him try and start that thing one cold morning...he didn't have it plugged in. Must have taken him at least half dozen tries to get it to finally catch and run, and then it was smoking, shakin and banging for at least 30 seconds before it smoothed out. My old cummins might have to crank 2 full starter revolutions to fire on the coldest morning...sometimes 2.5....:D
I like the faulty O.E.M head bolts in the 6.0L that lead to head gasket failure resulting in something like 20 hours labor. :D
Seriously, people... 4PSI at the main bearings with that kind of compression yet reading "NORMAL" on the gauge isn't mildly alarming?!
I couldn't believe that when he told me, but they tested and tested again... and again. That's insanity.
I did a serpintine belt, tensioner, and AC drive belt on a '08 ford with a 6.4 this week. That job pays 4.5 hr. of labor! $505.00 later he was on his way! I did valve cover gaskets on one a few months ago. Drivers side 2.5 hr. Right side, Lift the cab!
He did admit that the new Ford diesels are a much better design, but he still bitches that they stuck with a V8 rather than going to an inline six. :D
Jusr curious, but why are frequent oil changes so important on the Power Choke?
I didn't have an issue with oil changes on my Ford, but fuel filters had to be changed every 7500 miles. :hmmm: I do that on my Cummins too.
Other than the engine/trans, my Ford was a much better built, more solid feeling vehicle than my Ram. I see a Fummins in my future! :toot:
Because the injectors work partly off of oil. There's a high pressure oil pump, commonly abbreviated HPOP, that sends ~3000 psi of oil pressure to the injectors. The injectors are electrically triggered, but the high oil pressure is used to multiply fuel pressure to very high levels (exactly how high I don't know) INSIDE the injectors. Basically, they reached around over their shoulder to scratch their ass.
If I recall, the fuel pressure inside the injector is in the 30,000PSI range. Screw up an injector in a PowerStroke, it's likely the cab is coming off the truck to change it, too. I don't even think his shop will do a single injector, because if the one next to it fails a week later they're starting all over with the labor costs. As you can expect, customers get pretty irate about that.
You can get the injectors out without pulling the cab. It's not easy, but it can be done. Experienced techs can do it pretty quick, relatively speaking. Once you get to pulling the heads the cab has to come off.
I swapped injectors, and the HPOP on mine. HPOP was easier than I expected, the injectors on the other hand, no... I swapped them got it all back together and it wouldn't start, tore it down again to check and everything was right. Put it back together and I was forced to send it to the dealer and it was diagnosed with a bad fuel pump. With everything sealed it was fine, once the pressure was relieved the pump didn't have the balls to get the pressure back up.
I guess that sounds better than a CumStroke. :D
He's found the Fords to be more-problematic in other areas, too, particularly wheel bearings and the 4WD system, which is nothing short of retarded. If you're staying 2WD, though, you'd avoid those issues for the most part. His '99 Ram doesn't have a single squeak or rattle in it with well over 400,000 miles, which is more than I could say about my former co-workers '01 Super Duty, which had a much-smoother gas engine in it and 300K less miles on the clock. The Ford was a lot more roomy, though, and doesn't have the monkey-bar steering/track-bar setup of the older Dodge which has always been problematic.
I want a 4X4, I screwed up getting the 2wd, as I found in the dump the other day. I should've started looking for a Cummins CRD, and just put a trans and a tuner in my Ford.
That was a NICE, solid well maintained truck.
The BEST truck hands down would be a Cummins powered Super Duty.
I think I've done ball joints once on a Super Duty.
These guys are experienced. This is what they do every day. They know the fastest way to do these things due to experience. According to him, the labor rate is less to pull the cab but remember these guys also service OTR trucks so they have the stuff to do it quickly and correctly the first time.
Yup! There are kits, and companies that specialize in that very swap for a reason.
The '05-07 FX4 would be the deal, I'll take one of those with the Torqshift sissymatic and the tow/haul mode in Lariat with my Cummins.
Something like this would do.
By early 2007, the 6.0L PowerStroke had caused over $75 million in warranty claims to Ford. Getting out of their planned light-duty V6 "F150" PowerStroke cost them another $75 million to buy out of the contract with International/Navistar. Why do you think they abruptly cancelled the 6.0L and missed months of sales? Why else would they design their diesels in-house now?
I read that in the 'trades a few years ago, while driving a 6.0 my company provided me. Mine had few problems, though it never worked a day in it's life. All I did was drive it from customer to customer. I never understood why a Kenworth dealer would send it's salesmen out in International powered pickups instead of Cummins power, which we actually sold. My ex wife bought a 6.0 after we split, towed heavy with it, and as expected, it was a giant chunk 'o shit. My girlfriend also has an 05 6.0, and it's no different. 4 head bolts per cylinder is a recipe for disaster on an engine making 30+ pounds of boost. I cannot conceive the logic that Ford and International used to convince themselves that this was a solid design.
after driving around in a 00 SD for more than a year...im thankfull its NOT mine..its fullly loaded with every last luxury even leather...the seats are uncomfortable and the truck itself just..ugh...its had all sorts of electrical problems and the trans is going..the 4x system is GARBAGE...the engine on hard pulls or steep hills will suck its entire contents of oil out and burn it..and the rear diff has been warentyed out a few times with a "howl" on left handers...and that ABS is a JOKE ...its damn neer killed me in the gravel and snow
gimmy a cummins in a 70s dodge 1ton..
