Diplomat_Wagon
Hiding In The Bushes While
the rear spring mounting centers are ruffly 50 inches...outer edges of "stock" tires is 70 inches......sooo as long as your offset puts you not past 70 you will be fine.....on a side note..when i was cutting up the parts mini i loped out the wheel wells and checked how far in you could tub it befor hitting the frame..it was something like 7-9 inches ..so yeah you can tub the hell out of one without modding the frame...corse tubbing the drivers side would be a semi ugly task as the wheel well is extra long as the filler neck goes thru the wheel well...passenger side is a "normal" wheel well
as for the tank ..yes its offset but totaly in the way..(so in the way that they routed the exhaust to the passenger side on 2 90 deg bends to clear it) HOWEVER..i think if you found the tank from an AWD minivan that the tank is longer and skinnier by design to allow for the drive shaft of the rearend...dount quote me on it but im 90% positive that the AWD tank is totaly out of the way and that ALL vans have provisions for it...so essentialy it "should" be a direct bolt in...
ive seen a few "conversions" of normal minis being made AWD useing factory parts and was sure that everything to do it was a direct bolt in..with the exception of a few guys who did it to the "short" vans as the AWD was only availible on the long wheel base
some time this week/weekend ill end up out at the wreckers and ill see if theres any AWD's i can have a look at
Thanks so much 69! Your a great help!
I wonder if I should do a K-car?
Van or K-car?
