Last post for a while...mercifully.
All the painting was done in my garage. Built two paint booths. (have a 30x35 garage with 12 foot ceilings)
One around lift with car on it, and one smaller one for hood, doors and hinges.
Used DuPont base/clear coat system. And DuPont VeriPrime primer. About 20 hours of prep, maybe an hour of spraying. Used HVLP gun from Home Depot. This was the first automotive painting I'd ever done. Took my time, was careful, especially in cleanliness and mixing paint. Use liberal amounts of sanding, and prep sol before spraying. Had a few areas where new paint reacted with old but nothing major.
Oh yeah, in case anybody's interested, a quart of base coat, plus the thinner, a quart of clear coat, plus the activator is $122.00 give or take a buck or two! So far on fourth quart. Plus three quarts of VeriPrime and activator at $45 each! Gahhh...where's Earl Schribe when you need him.....
Didn't do the rotisserie thing as I just don't have the facilities available so this was next best. In reality this is a restoration to street drivable condition, not concorse show stuff. I want to drive this car! Be seen in this car! Cruise the local Sonic Drive In in this car. Not haul it around in a trailer!
Learned a lot in what I've done so far. Have the trunk lid, the trunk, the front and rear valences to do, plus the frame/body behind the rear bumper and the inside of the fenders.
Planning on having the outside done professionally as I don't have a big enough and clean enough paint booth. But as I go along I may change that.
I've done the bottoms of the rocker panels and lower frame back to and including the crossmember.
Biggest task remaining is stripping the Ziebart undercoating off the inside of the rear wheel wells and frame. Nasty, dirty, hot, lousy, time consuming work! But since this is my "baby" and I'm retired, I don't mind
Well so much for the update.
Off to the Indy 500, then Texas Motor Speeway, and back to Indy for the USGP. So no work on the Roadrunner for a month!
Will post more later....
PS Is this a disgusting picture or what? Taken after "paint day three!"
