between lettting panels cool or dust settle ive been trying to figure out a solution for heater, initialy i was going to run 70s toyota pickup unit as they are pretty small, thing is even that is too big to fit, i had also picked up a 93? vw euro van floor heater, its pretty compact and would actualy fit in the doors , i also picked up the AC unit from the same rig, pretty cool and compact, bonus its not part of the heater in any way...the ac will mount in the rear with vents going forward
the problem ive got up front for heat is a serious lack of space, 8 inches wide and about 11 inches tall , thats what ive got to work with for "un-used" space, as of right now im looking at cutting up the vw heater unit and "clocking" some sections, it will be twice as effective as the toyota unit just in design, never mind the core being double the size, right now as t looks if i clock the motor 90 and then clock the output 90 ill have a unit 8 inches wide 11 inches tall with a tapper down to fit in the console curve without eating gauge or radio space, but its going to be TIGHT
ive scoured the wreckers for small heaters for many many years now for parts for other projects ALWAYS keeping an eye out for lloyd parts like a heater, the 93 euro van unit i have was picked up late last year in fact, while work on the lloyd may have died while i wasnt posting i NEVER stopped gathering parts/supplys as i could find them/afford them
most heaters are MASSIVE as they contain both heat and air with a million vent ports etc, the smallest unit without modding ive found to date is the toyota pickup units from the 70s-early 80s. however it too is too big and would need modded even more than the vw unit to only net me with a "ok" heater with its ancient core design and oversized blower motor, ill be shooting pics when i start hacking up for visual referance
ive checked this from every angle, ive got 4 options
move the heater to the trunk..sure but how much heat will you scrub in the distance so that defrost no longer works
axe the glove box(seriously considering this) but the heater would still have to be a custom build
hack up and slot into the space i do have
axe the power windshield plan and budge out the firewall for it.....probably the simplest solution but....NO ONE as best i can tell has ever done a power windshield that totaly hides away....so i want to BAD
as of today running numbers checking space behind the guages in the console, it looks like my best bet is to basicly make my own box and slot the vw parts into it, as the parts without box fit without issue, the thought of axing the glove box is tempting regardless since what do i need to put in it besides registration
id KILL for a "petrol" gauge in black with white marks chrome ring, no not a fuel gauge one that actualy says petrol, im looking for 50/60s vintage gauges for the console, temp, oil, fuel, tach, or mini tach and clock ...call it one of my missing pieces
