I've been planning this sense last fall. The auto started to slip in drive & the torque converter has been acting up for years so rather than spend the money rebuilding the one thing I never really liked about the car I made the decision to cut it.
I ran the idea past Jass and he didn't respond the way I expected. I fully expected him to say "Don't do it! It's to original." He was all for it. In fact he helped me compile a list of needed parts. I had the transmission "in Stock" It is a 1970 big block unit. with the good SR307 synchro rings and the super awesome 2.66 1st gear. The Big block trans required a OD bell housing to fit the bearing retainer. I had the bell housing "In stock".
Jass found a auction on E-Bay for most of the tuff stuff to find which I won. (Truth be told only two bids were placed, his then mine. Jass bid on it first just incase I got busy and forgot to. What a buddy)! It had the bell crank, bench seat shifter bracket, shift rods, levers, shifter (that I didn't use) and a super nice original pistol grip shift handle. Next thing to acquire was the floor hump. That Jass guy bought me a AMD piece and gave me it and the dash revers light with wire harness for my Birthday. So I'm guessing he is on board with the swap at this point. I had an A-Body manual column here that I picked up in our favorite salvage yard years ago. I molested it for the non column shift parts and swapped them over to my B-body auto column. Yes. Its that easy. They all swap over!
The rest of the parts came from
Brewers Performance. I bought the pedal set, transmission bearing and gasket kit, clutch rods, shifter boot and trim ring, clutch fork pivot, hardware for the trim ring and shifter boot, Reverse light wire harness, and clutch inspection cover from them. I can't say enough good about these people. They are super helpful, super fast on shipping and they answer every E-mail within minutes. Every damn business out there can take lessons from these people!
The clutch, paint, & seam sealer & ARP flywheel bolts were purchased through work (Breeze Auto). The clutch bolts and pilot bushing were bought through
Mancini Racing. The carpet set is a ACC set that I bought through
Rock Auto. I had my neutral balanced flywheel drilled for the cast crank 340 balance at
Flemming Fab. The shifter I used is a Jefferson Swap meet find. Its a factory rebuilt hurst super shifter.
The majority of the work happened the week my Dad passed away. I had pulled it in the garage, got it on stands and pulled the carpet set. The next night he fell and hit his head quite hard. He passed the next day. The next two days I threw myself at the project to keep my mind busy. It worked. I was able to have some time to myself and just stay busy.
I wish my Dad could see the result. He too surprised me with his response when I told him my plans last fall. He said "Cool" I'm surprised you didn't do it sooner!"
Restoman was a huge help through this. He was at a key flick away with advice and moral support every time I needed it. Thank you so much for that. You are a hell of a internet teacher. I wish I could spend "hands on time" learning from you in person. Jass was a huge help too. With parts searching, moral support, and a extra set of hands when I needed it too. Chrissie's Dad helped a ton as well. He was right there with me when I was silently cutting and wrenching, working my way through my Dads passing. Trent is a hell of a guy and I'm damn honored to be his son-in-law.
