thrashingcows
Did an oil change on Patches 4 days ago and every day I've used it going to and from work I have been getting a hot, burning oil smell from under the hood. I don't have any visible new oil leaks, none that have not been there for quite some time, but I can't determine where it's coming from. Seems to be more prevalent on the passenger side of the engine bay, but that could be because from the engine fan blowing that direction.
Only thing I can think of is a bad or faulty oil filter...I did touch it while still running after I got home and it was very hot but I don't usually touch the oil filter so I'm unsure as to how hot it actually was...believe I read somewhere they should be about 10-20* deg more than the coolant temperature? Guess I should go for a drive and then use my inferred thermometer to check the temperature of the oil pan VS the oil filter.
