69.5CUDA
Blah Blah Blah
everyone thinks about it but it seems few speak of it....
right now im in need of re-doing my whole setup as ive gotten to a point where i KNOW where my drops will stay forever...and im sick and tired of the air leaks...hoses ziptied to the walls to the drops works great till you get tired of the moisture problems and air leaks..but its IDEAL for figuring out your final routing
anyway...there have been alot of theroys over the years...some good some bad some silly...
abs/pvc...simple, cheep, easy to mod and work with....but once aged...yeah the shattering storys are scary and if/when you can find carnage pics you relaize how dumb of an idea plastic is
steel....while solid, fairly easily worked with and bulletproof by nature..you get an unseen vilan...RUST in the air
copper...expensive, a pain to work with....but once done means no moisture issues
stainless steel..you will NOT find this stuff off the shelf....but if you want the best..this is it
aluminum....this seems to be the new standard for industrial aplications....again..your not going to find it off the shelf
"hybrid" ...its similar to pex..some versions have thin aluminum in it as well.....i have little to no info on this "new" setup..lots of different sizes and flavors of kits
https://shop.rapidairproducts.com/p...MfXAgW0u7gEi_dEInklTaz62N_VlAE1iVoaAglC8P8HAQ
now heres the real thing that i dont see addressed anywhere..and thats line size,,,industrial runs 1-2inch..anyone else runs whatever they seem to get the best deal on....the hybrid stuff that ive seen localy is just a smidge bigger than the nipple in your air chuck......
so whats "ideal" on size....right now im looking at either the 50$ 3/8s hybrid "kit" 80$ 1/2 hybrid "kit" or about 80 ..or going copper 1/2 is about 80$ and 3/4 would be about 110-120......however if i go with a "kit" i can do the extra drop id like to add at the garage door...it would be another 40-75$ for the copper so it would wait
