So today was laying out the wiring up front, while I was out there I started up the heater in the garage so I could paint the drums.
light harness looks good, just one wire I have to look up red wire (extended in black) off the light harness
On the neutral safety, 2 questions, should I at least tape or sleeve those bare wires all the way down to the tranny? & on my main plug there's an extra wire (brown w/yellow tracer) quite long not sure where that goes or if I need it, I think I have another plug without that?
I need a coil, should I just order a stock one, everything else is now stock.
Not sure I can use the one that came with that old distributor?
choke, alt & washer pump wires are in the right places.
think I have to otder the wire holders, most of the old are broken.
Then it was inside to warm up & work on the drums, somehow I can't stop myself, ended up almost at bare metal.
the clear is still wet, but I had a lot of matt clear that I don't think I need any more so I used that since they won't show & saved the satin for up top.
