Another good news bad news day, one of my back orders came, now all I need is the leaf spring shackle bushings & I can (if I ever get my axles back) assemble the rear end.
Sway bar bushings
Then I decided to tackle the freeze out plugs, now the ones I pulled out were not as deep as 2 different howto videos showed.
Just to be safe I put a light coat of copper permatex on em.........
2 to the front look about as recommended, the rear (on the right) I may have pounded once too much, I hope it's not a problem?
have to reverse for a moment, I punched holes in a couple before they would budge.......
& there was some nasty lookin stuff in there I was going to dig out the power washer, but I brought the hose over first & I think that was enough. flushed it out in every direction I could hit till it ran clean, then pulled out the heat gun & dried it all out, cause it will be sitting quite a while longer.
& that's where it goes bad, the plugs on the heads are smaller & they had ONE in the kit, I need 5, so I'm short 4, hope I can buy those separately, I am getting a little upset that about half the stuff I get is screwed up!
So I taped one side off got it primed...........
& painted. Taped off all the holes in the other side & will wait on the rest of the plugs!
