Rav's intake
Rob R
Well I'm going to be starting on Rav's intake this weekend...little port work on the inside and a port match to the heads it will be NICE once it's finished...should be worth about 8-15 hp and tq from it's out of the box condition...
I had to clean it up before I started...just can't seem to get excited about porting a grungy old intake...
looks GREEEEAT ROB :giggedy: :2thumbs: , cant wait to get the 440 & the rr back togather and outta the garage on the road .
i just have to come up with a another grand or two to get it road worthy . [smilie=2: :) .
thanks RANDY
Just say no to aluminum carb spacers Rav, they transfer way to much heat. Get a wooden one and your carbie will stay much cooler and happier, trust me. ;)
A12...I just gave it a quick blast with some glass bead...
mopar...I'll take some pictures as I go along ;)
Rav...one inch might be a bit too tall...Im going to put a head on the flow bench and put the intake on it and see how much spacer it likes...
Glass beading is the shiznit! My buddy that runs a machine shop has a nice blasting cabinet-I use it on everything I can.
Roofs roughed in...
how do you add another picture to a post :huh: ...I tried to add this picture to the first two and I can't do it...GRRRRRRRRRRR
:giggedy: :bravo: :giggedy: looking good :giggedy: :bravo: :giggedy:
Boy this intake need a lot of grinding...!!! :doh: I've never seen an intake wall divider so thick before.... .358[smilie=2: small intake port opening:confused: kinda reminds me of those old SP2P intakes...(almost)
Just edit the post and add in your IMG tags and link where you want them.
[img]http://www.mts.net/~reidfam/ravintake2.jpg[/img]
Boy this intake need a lot of grinding...!!! :doh: I've never seen an intake wall divider so thick before.... .358[smilie=2: small intake port opening:confused: kinda reminds me of those old SP2P intakes...(almost)[/quote]
utoh [smilie=2: [smilie=f:
;) :bravo:
:bravo: thanks ROB . keep up the hard work :bravo: i wish there was away i could get the 440 to you to get it built the way it should .
what C.I.D. is the 440 @ .030 over ?
At .030 it would make it a 446 ci in...just think at 1.25 hp per ci in you should have 557 hp :giggedy:
:giggedy: 557 HP :giggedy: it just keeps getting better :giggedy:
ROB , what do you guesstimate it had with stock intake unbreathable 213 heads and the eddy 750 vac 2ndarys ? out of the box it was rated 285 HP .
would you guess around 325 HP or so ?
:bravo:
