thrashingcows
You don't want a separate incoming line. That would mean the cost of another meter and another, separate bill. Electric companies charge a standard monthly hook-up fee per meter.
Running 220v service is easy if you have basic knowledge of household wiring. First make sure you have ample service to the house. 200 amp service is desirable, but 100 amp will suffice, depending on how much equipment you run.
If your panel has space for another 220v breaker, you're good to go. If not, that's the first thing to remedy. From there run 8 awg underground in plastic conduit to the outbuilding. Most codes specify a minimum of 18" coverage. But if you're on your own, 8-10" is good. Depending on local codes you may be able to do this without a permit. (I did for mine) Then again, what they don't know won't hurt. :silenced: You probably want a 100 amp breaker in-house to the shed. In the shed you can go either with 60 or 100 amp, depending on usage.
I wired my 2 garages as therapy after my rotator cuff surgery. :doh:
Ahhh I see....thank you 68 for that sagely info....
Would the 8 awg have to be a multi string? Or just the one main power wire, and ground at the shop end?
