MOPAR MARV
Manic Mechanic
A few months back I did some reconstructive surgery on the master bath in a 1970s house trailer for a dis-abled friend and was given a one owner, very low miles '94 Concorde as partial payment for all the work.
The problem is that the car sat un-used for extended periods of time and now pretty much the entire brake system is jacked , the ABS lite is on full-time, calipers stuck solid, Master Cylinder will not build pressure , with little to no brake pressure to one front wheel and one rear wheel.
I've tracked down, Rotors ,brake pads, replacement calipers, two front Brake Hoses and one Rear hose. Then I'm told I can not get a left rear brake hose and that both master cylinders[ABS and non ABS] are no longer serviced in Canada!!!! I need the 4 wheel ABS unit.
Nobody in Canada has been able to track one down for me!! {insert many curse words here!]
So now I'm thinking that I'm going to have to adapt another system into the car and I'm throwing the door open here looking for any suggestions on maybe a newer mopar set up that would work with out too much hassle.
I'm totally open to losing the ABS, I hate it anyway, so let the ideas fly.
