thrashingcows
OK so now that Christmas and the holiday season is over I can start getting to the 4 post lift.
First off is one of the pulley shafts got bent...not sure if the reason for the retirement of the lift, or maybe happened during disassembly, or perhaps when we were loading it and all the columns and hardware shifted and slid together, regardless it is damaged and needs to be fixed.
Clearly this lift sat outside for a year or two...the corrosion is a bit more then I'd expect on a lift that was recently retired, oh well time to pull everything apart and clean, fix and replace as needed.
Here is the bent pin with one of the other ones...
It's 3/4 round bar by about 6.75" long.
Now due to the corrosion I figure I'll just replace all the pins in the system since they do need to spin nice and easy for maximum efficiency of the system. The pins don't appear to have been chromed, but maybe a low grade stainless, they are magnetic. For replacement would just basic cold rolled steel bar be fine or should I go with stainless bar, or maybe a plated pin?
