I guess I've never seen any advantage or benefit to hydraulic clutch linkage where a factory mechanical setup is an option. Any "mechanical advantage" that would make clutch disengagement easier is actually a function of the diaphragm clutch you're forced to run, not the hydraulics. The fact that you're limited to a diaphragm clutch speaks to its fragility--Dodge trucks used hydraulic actuation with brutal 11"-14" Borg & Beck clutches for years without issue (with plenty of required pedal pressure, no less)--but this setup can't survive one? Worse, a hydraulic component failure leaves you with only one option yet again: calling Dr. Hook, then the wait for replacement parts to ship. Conversely, Stee-retch recently had a mechanical linkage incident in a parking lot but was able to get himself roadworthy in about 15 minutes.
I have '70-'72 pedals and linkage in my Valiant with a McLeod Borg & Beck-style pressure plate. The clutch is easier to modulate,
and requires less effort, than either the OE hydraulically-actuated diaphragm clutch in my old V6 Dakota or EFI Ed's 11" Centerforce. It has greater clamping load, too, without the mushy feedback-free feel of a diaphragm clutch. It's literally less of a leg-buster while still managing to feel like an actual clutch. Of course, like all Mopars it's got a giant over-center spring to assist with clutch disengagement. All the wearing parts in the linkage got new, well-lubricated replacements, and all the metal-to-metal contact points were lubricated with Slip-Plate #2 (rhat stuff's magic, I tell ya). Everyone that's pushed that pedal has been startled by how light it is for a relatively-stout clutch.
I didn't even have
pedals when I started, and the complete setup from pedal pad to throwout bearing was considerably less expensive than that hydraulic kit. The only failure-prone parts in the factory linkage are that stupid rubber bushing where the pushrod meets the clutch fork, and the countershaft (Z-bar) itself. The latter's only a problem with a hairball clutch (which you won't be running) and the former is an easy factory fix: part #2401740. It's an OE truck part that replaces the crappy rubber bushing with a formed steel ball. Not only is it indestructible, it improves pedal effort and feel. Yep, it's expensive (at least on eBay) but it's worth every nickel. I won't assemble a linkage without one.
The easiest, and probably best option if someone wants a light pedal would be to use a diaphragm clutch with factory mechanical linkage (including the ball upgrade), then remove the over-center spring from the pedal. The "replacement" clutches offered by most manufacturers (Perfection, Valeo, LUK) these days are diaphragm-style. Perfection even offers a "high clamp load" option under part number 30027, whoring the once-proud Zoom name in the process. The OE linkage will live forever and a day with the light load of a diaphragm clutch and no over-center spring, and the clutch itself should be smooth and easy to disengage. And mushy, because diaphragm.
