b-body-bob
I finally got the hood close to where it needs to be but it still stops about an inch above where it should. It really seems like it should move toward the passenger side, but if you know A-body hoods you know there is really no side to side, only front-back and up-down. Any side-to-side would be because one side is farther forward than the other so it's not sitting in the hole straight.
The slotted holes are oriented so you don't get any real front-back motion out of those. The rear-most bolt is for up-down angle of the hood. So there you snug the front bolt and loosen the rear bolt, hold the hood at the angle needed in relationship to the hood, and tighten the bolts.
To move the hood front-back you have to loosen things up to where you can slide the hood on the inserts. So that means both bolts have to be loose to make the adjustment, very loose. Once it's loose enough to slide, the weight pulls the front of the hood down and the rear edge of the hood up. This is madness LOL.
I have tried raising it up the bare minimum, when I loosen the bolts the front of the hood still goes down and the back up, and when I try to pivot it down from that position I either close the hinge, or push it open. So the bare minimum gives me nothing.
Another hassle is that I'm pretty sure with the angle the rear-most slotted hole is cut, the hood doesn't move straight up and down but also in and out in relation to the cowl. So I've had no joy setting one adjustment, then the other.
Also I read that the bumpers along the inside of the fender are to align the hood. They are all in place along the driver's side fender so they should be pushing the hood to the passenger side, but they aren't. It is actually way too close toward the driver side. Right now I suspect that is the reason the hood won't close completely - it is closing on the bumpers instead of sliding over them. Maybe I should lube them? Yes they do fit in the recesses stamped into the hood.
I feel like I did with those damned clutch linkage clips - there is a method that makes this easy, I just haven't found or figured it out yet.
More finagling and cursing is in my future but I won't be defeated.
