more unobtanium
69.5CUDA
Blah Blah Blah
anyone want to find an impossible part..or atleast something that will work the same?
i need a piston and rings
1983 honda xl600r
.5mm over(aka .020 i think)
what i CAN find is crazy 10.5+ comp slugs which i really dont want to do..im not looking for more power...close to 50hp on a 600cc dirt bike is PLENTY..and hard enuf to kick over that big single
i was going to get one direct from honda..but..it no longer exists..and the bore had to be taken beyond the .25 thats availible still
below is what i need
[h=1]13103-MG2-003 PISTON (OS) (0.50)[/h]
Bike parts aren't my strong area, 69.5. But believe me, if you think nearly 50HP is plenty on a 600, try it on a poked-and-stroked '87 XR200R with drum brakes at both ends. 247cc and about 40HP. I think it was around the same compression, but with the cam and the aluminum head it ran fine on 93. Thumper Racing did the engine.
doc my 6 has drums on both ends..someone put xr350 parts on the bike..enuf grunt to pul the front thru the first 3 gears off road and if you poke it hard enuf pull it in 4th on road..yeah i dont NEED more power
yay ill give em both a call and see if they ACTUALY have em..cause if they are like my local shop they get direct from honda and just didnt know it wasnt availible from honda
