ignition switch
ill take a look around i "should" have onejust gotta find my key box...cause it would be hiding in there ...if you have some door lock cyl's you should check them with that ignition key..it should match a pair of door locks that i personaly pinned to match it so youd have 1 key for all 3 just as the factory intended
ya i was hunting for the matching door locks too ... i have a pair but the ignition key didnt work in them. I have a matching set from a dart that was junked so i was planning to swap the cylinders.
