69.5CUDA
Blah Blah Blah
ok guys..this one is just out side of my current brain power as ive never dabbled into it...so..i need some pointers and do's and donts
got a 72 oliver with a late 70's mighty hoe on the back....the hoe runs off the pto
the hoe is doing some WEIRDNESS....swing right is slugish swing left is normal..right leg will lift the tractor left leg struggles or fails....pulling and lifting is pretty much stopped it wont do it....pushing out with the bucket is also pretty useless while pulling will actualy drag the tractor
this all came on all of a sudden..but i know my boss ran it pretty empty..we put in close to 8galons to fill it back up...im starting to wonder if some damage has been done to the pto by running it too low?..or is there air in the ssystem that needs bled out or something?...as the sluggesh bits move you can feel them surge and drag on the engine rythmicly
the more i worked the legs the better it got..so i went out to dig on the burn pit and everything got bad..real bad ..so bad i wasnt sure id get the hoe all retracted up .....when i parked it and shut it off ...i pulled the leg levers and 1 droped as one would expect the other just kinda crept a lil and stopped
