Still workin on the rear end, also tore down the block finally, another broomstick for a cam, oil pump & 2 pistons done! [smilie=2:
Well, Eagle H-beam rods and Wiseco pistons on the way!
oh yeah Ron, Roller cam on the way, i ain't putting up with this solid cam crap anymore!!
Anyone need some LY rods with Milidon bolts?[/quote]
Dang Kev.....that is some bad luck !! [smilie=e:
How bad are the cylinder walls....do they need a re-bore ? The new rods and slugs are worth it for this type of application, no doubt. Can't argue with the roller cam other than the added cost for hard parts associated with the swap. This flat tappet issue needs to be addressed....too many failures in the last couple of years....quality control sucks !!! [smilie=2:
I guess i was lucky with mine but the spring pressures aren't excessive with the stock e-head springs (340 open). Any grind requiring 400lbs open pressure will be getting schubecs on any motor of mine...guaranteed.
Sorry to hear about this buddy. Good luck with the rebuild....she'll be sweet when finished !
Ron
