From Pirelli
Italian tire manufacturer Pirelli has revealed the tires that will be taken to the Grands Prix of Belgium, Italy and Singapore.
Belgium
At Spa - one of the most spectacular and demanding circuits on the calendar - the P Zero White medium and P Zero Yellow soft tires will be used, which will be well-suited to the varied track and weather conditions often found in Belgium.
Italy
For Monza, the ‘temple of speed' and Pirelli's home event, the two hardest compounds in the range have been nominated: P Zero Orange hard and P Zero White medium. This is to combat the high-energy loads that are put through the tires as the result of high traction and braking demands, sustained high speeds and frequently warm temperatures.
Singapore
Singapore is the final street circuit of the season and held at night, providing a unique combination of conditions. The two softest tires in the range will be used: P Zero Yellow soft and P Zero Red supersoft. These will provide maximum mechanical grip.
[TD="class: caption"]Photo: Pirelli[/TD]
More...
Belgium
Italy
Singapore
More...
